IE5351
IE5351
    IFM(易福门)
    圆柱形,有螺纹-M8
    INDUCTIVE PROXIMITY SENSOR,8MM D
IE5351 数据手册
IE5351 Inductive sensor IEBC003BASKG/0,3M/US Product characteristics Electrical design PNP/NPN Output function normally open Sensing range [mm] Housing Dimensions 3 threaded type [mm] M8 x 1 / L = 37 Electrical data Operating voltage Current consumption [V] [mA] Protection class 10...30 DC < 10; (only in 3-wire operation) III Reverse polarity protection yes Outputs Electrical design PNP/NPN Output function normally open Max. voltage drop switching output DC [V] 2.8 Minimum load current [mA] 2; (only in 2-wire operation) Max. leakage current [mA] 0.5; (only in 2-wire operation) Permanent current rating of switching output DC [mA] Switching frequency DC [Hz] Short-circuit protection 100 1000 yes Type of short-circuit protection pulsed Overload protection yes Detection zone Sensing range [mm] 3 Operating distance [mm] 0...2.4 Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.7 / brass: 0.5 / aluminium: 0.4 / copper: 0.3 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IE5351-00 — 13.04.2023 — IE5351 Inductive sensor IEBC003BASKG/0,3M/US Hysteresis [% of Sr] 1...15 [°C] 0...60 Operating conditions Ambient temperature Protection IP 67 Tests / approvals EMC EN 60947-5-2 MTTF [years] UL approval 1517 Ta -25...80 °C Enclosure type Type 1 power supply Limited Voltage/Current File number UL E174191 Mechanical data Weight [g] 31.2 Housing threaded type Mounting Dimensions flush mountable [mm] M8 x 1 / L = 37 Thread designation M8 x 1 Materials brass white bronze coated; sensing face: LCP Displays / operating elements Display switching status 1 x LED, yellow Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IE5351-00 — 13.04.2023 — IE5351 Inductive sensor IEBC003BASKG/0,3M/US Electrical connection - plug Cable: 0.3 m, PVC; 3 x 0.14 mm² Connector: 1 x M12; coding: A; Locking: rotatable ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IE5351-00 — 13.04.2023 —
IE5351 价格&库存
很抱歉,暂时无法提供与“IE5351”相匹配的价格&库存,您可以联系我们找货
