IG0350
IG0350
    IFM(易福门)
    圆柱形,有螺纹-M18
    INDUCTIVE PROXIMITY SENSOR,18MM
IG0350 数据手册
IG0350 Inductive sensor IGB2008-ABOA/SL/LS-100AK/RT Product characteristics Output function Sensing range normally open [mm] Housing Dimensions 8 threaded type [mm] M18 x 1 Electrical data Operating voltage [V] Protection class 20...250 AC/DC I Reverse polarity protection no Outputs Output function normally open Max. voltage drop switching output DC [V] Max. voltage drop switching output AC [V] 6 6.5 Minimum load current [mA] 5 Max. leakage current [mA] 2.5 (250 V AC) / 1.3 (110 V AC) / 0.8 (24 V DC) Permanent current rating of switching output AC [mA] Permanent current rating of switching output DC [mA] Short-time current rating of switching output [mA] Switching frequency AC [Hz] 25 Switching frequency DC [Hz] 100 250; (350 (...50 °C)) 100 2200; (20 ms / 0,5 Hz) ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IG0350-00 — 13.04.2023 — IG0350 Inductive sensor IGB2008-ABOA/SL/LS-100AK/RT Short-circuit proof no Overload protection no Detection zone Sensing range [mm] 8 Real sensing range Sr [mm] 8 ± 10 % Operating distance [mm] 0...6.5 Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.7 / brass: 0.5 / aluminium: 0.4 / copper: 0.3 Hysteresis [% of Sr] 3...15 Switch point drift [% of Sr] -10...10 [°C] -25...80 Operating conditions Ambient temperature Protection IP 67 Tests / approvals EMC EN 60947-5-2 EN 55011 MTTF [years] UL approval class B 604 Ta 0...40 °C Enclosure type Type 1 power supply Hazardous voltage File number UL E174191 Mechanical data Weight [g] 59.9 Housing threaded type Mounting Dimensions non-flush mountable [mm] M18 x 1 Thread designation M18 x 1 Materials brass nickel-plated; PC Displays / operating elements Display switching status 1 x LED, red Electrical connection Required protection miniature fuse to IEC60127-2 sheet 1; ≤ 2 A; fast acting Accessories Items supplied lock nuts: 2 Remarks Remarks Pack quantity Recommendation: Check the safe functioning of the unit after a short circuit. 1 pcs. ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IG0350-00 — 13.04.2023 — IG0350 Inductive sensor IGB2008-ABOA/SL/LS-100AK/RT Electrical connection - plug Connector: 1 x 1/2"; coding: C Note miniature fuse to IEC60127-2 sheet 1 ≤ 2 A fast acting ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IG0350-00 — 13.04.2023 —
IG0350 价格&库存
很抱歉,暂时无法提供与“IG0350”相匹配的价格&库存,您可以联系我们找货
