IE5391
IE5391
    IFM(易福门)
    圆柱形,有螺纹-M8
    INDUCTIVE PROXIMITY SENSOR,8MM D
IE5391 数据手册
IE5391 Inductive sensor IEK3004-BPKG/V4A/K1/AS Product characteristics Electrical design PNP Output function normally open Sensing range [mm] Housing 4 threaded type Dimensions [mm] M8 x 1 / L = 60 Application Special feature Gold-plated contacts; Correction factor K = 1; Magnetic-field immune Magnetic-field immune yes Max. magnetic field immunity [mT] 300 Electrical data Operating voltage [V] Current consumption [mA] Protection class 10...30 DC < 20 III Reverse polarity protection yes Outputs Electrical design PNP Output function normally open Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] Switching frequency DC [Hz] 2.5 100 1000 Short-circuit protection yes Overload protection yes Detection zone Sensing range [mm] 4 Real sensing range Sr [mm] 4 ± 10 % Operating distance [mm] 0...3.25 Accuracy / deviations Correction factor Hysteresis steel: 1 / stainless steel: 1 / brass: 1 / aluminium: 1 / copper: 1 [% of Sr] 1...20 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IE5391-02 — 17.07.2017 — IE5391 Inductive sensor IEK3004-BPKG/V4A/K1/AS Switch point drift [% of Sr] -10...10 Correction factor K = 1 yes Operating conditions Ambient temperature [°C] -25...70 Protection IP 65; IP 67; (with ifm socket duly screwed on) Tests / approvals EMC MTTF EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V EN 55011 class B [years] 544 Embedded software included yes Mechanical data Weight [g] 20 Housing threaded type Mounting non-flush mountable Dimensions [mm] M8 x 1 / L = 60 Thread designation Materials M8 x 1 housing: stainless steel (1.4404 / 316L); sensing face: LCP; lock nuts: brass Displays / operating elements Display switching status 4 x 90° LED, yellow Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M8; coding: A; Locking: snap-fit ; Contacts: gold-plated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IE5391-02 — 17.07.2017 — IE5391 Inductive sensor IEK3004-BPKG/V4A/K1/AS Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IE5391-02 — 17.07.2017 —
IE5391 价格&库存
很抱歉,暂时无法提供与“IE5391”相匹配的价格&库存,您可以联系我们找货
