IN0117
IN0117
    IFM(易福门)
    模块
    INDUCTIVE PROXIMITY SENSOR 4MM N
IN0117 数据手册
IN0117 Inductive dual sensor for valve actuators IND2004DAROA/SL/LS-500 RT Product characteristics Output function Sensing range 2 x normally open [mm] Housing 4 rectangular Dimensions [mm] 40 x 26 x 26 [Hz] 47...63 [V] 20...140 AC / 10...140 DC Electrical data Frequency AC Operating voltage Protection class I Reverse polarity protection no Outputs Output function 2 x normally open Max. voltage drop switching output DC [V] Max. voltage drop switching output AC [V] 5 5 Minimum load current [mA] 5 Max. leakage current [mA] 0.8 Permanent current rating of switching output AC [mA] Permanent current rating of switching output DC [mA] Short-time current rating of switching output [mA] Switching frequency AC [Hz] 25 Switching frequency DC [Hz] 25 200 200 900; (20 ms / 0,5 Hz) ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IN0117-00 — 13.04.2023 — IN0117 Inductive dual sensor for valve actuators IND2004DAROA/SL/LS-500 RT Short-circuit proof no Overload protection no Detection zone Sensing range [mm] 4 Real sensing range Sr [mm] 4 ± 10 % Operating distance [mm] 0...3.25 Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.7 / brass: 0.4 / aluminium: 0.3 / copper: 0.2 Hysteresis [% of Sr] 3...15 Switch point drift [% of Sr] -10...10 [°C] -25...80 Operating conditions Ambient temperature Protection IP 67 Tests / approvals EMC EN 60947-5-2 EN 55011 MTTF class B [years] 502 [g] 78.5 Mechanical data Weight Housing rectangular Mounting non-flush mountable Dimensions [mm] 40 x 26 x 26 Materials stainless steel (1.4305 / 303); PBT Displays / operating elements Display switching status 2 x LED, red Electrical connection Required protection miniature fuse to IEC60127-2 sheet 1; ≤ 2 A; fast acting; Place the fuse outside the hazardous area. Remarks Remarks Pack quantity Recommendation: Check the safe functioning of the unit after a short circuit. 1 pcs. ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IN0117-00 — 13.04.2023 — IN0117 Inductive dual sensor for valve actuators IND2004DAROA/SL/LS-500 RT Electrical connection - plug Connector: 1 x 7/8"; coding: A Note miniature fuse to IEC60127-2 sheet 1 ≤ 2 A fast acting Place the fuse outside the hazardous area. ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IN0117-00 — 13.04.2023 —
IN0117 价格&库存
很抱歉,暂时无法提供与“IN0117”相匹配的价格&库存,您可以联系我们找货
