IM0041
IM0041
    IFM(易福门)
    模块
    INDUCTIVE PROXIMITY SENSOR, 40X4
IM0041 数据手册
IM0041 Inductive sensor IMC2035-ARKA/LS-100AK Product characteristics Output function Sensing range normally open [mm] Housing 35 rectangular Application Special feature Increased sensing range Electrical data Frequency AC Operating voltage [Hz] 47...63 [V] 20...140 AC / 10...140 DC Protection class I Reverse polarity protection yes Outputs Output function normally open Max. voltage drop switching output DC [V] Max. voltage drop switching output AC [V] 5.5 5.5 Minimum load current [mA] 5.5 Max. leakage current [mA] 1.7 (140 V AC/DC) Short-time current rating of switching output [mA] Switching frequency AC [Hz] 25 Switching frequency DC [Hz] 100 2200; (20 ms / 0,5 Hz) ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IM0041-00 — 13.04.2023 — IM0041 Inductive sensor IMC2035-ARKA/LS-100AK Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Detection zone Sensing range [mm] 35 Operating distance [mm] 0...28.3 Increased sensing range yes Accuracy / deviations Correction factor Hysteresis steel: 1 / stainless steel: 0.7 / brass: 0.4 / aluminium: 0.4 / copper: 0.3 [% of Sr] 3...15 Operating conditions Ambient temperature [°C] -25...70 Protection IP 67 Tests / approvals EMC EN 60947-5-2 MTTF [years] UL approval 353 Ta 0...40 °C Enclosure type Type 1 power supply Hazardous voltage File number UL E174191 Mechanical data Weight [g] 254.55 Housing rectangular Mounting non-flush mountable Materials PPE; clamp: diecast zinc Displays / operating elements Display switching status 1 x LED, red operation 1 x LED, green Remarks Remarks Pack quantity 5 positions of the active zone possible 1 pcs. ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IM0041-00 — 13.04.2023 — IM0041 Inductive sensor IMC2035-ARKA/LS-100AK Electrical connection - plug Connector: 1 x 1/2"; coding: C; Locking: brass ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IM0041-00 — 13.04.2023 —
IM0041 价格&库存
很抱歉,暂时无法提供与“IM0041”相匹配的价格&库存,您可以联系我们找货
