IQ2002
IQ2002
    IFM(易福门)
    模块
    INDUCTIVE PROXIMITY SENSOR, 20 X
IQ2002 数据手册
IQ2002 Inductive sensor IQ23008BBPKG/0.3M/PUR/US 1 2 LED yellow LED green Product characteristics Electrical design PNP Output function normally open Sensing range [mm] Housing Dimensions 8 rectangular [mm] 20 x 8 x 32 Application Special feature Increased sensing range Electrical data Operating voltage Current consumption Protection class Reverse polarity protection [V] [mA] 10...30 DC < 10 III yes Outputs Electrical design PNP Output function normally open ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IQ2002-00 — 13.04.2023 — IQ2002 Inductive sensor IQ23008BBPKG/0.3M/PUR/US Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] Switching frequency DC [Hz] 2.5 100 400 Short-circuit protection yes Overload protection yes Detection zone Sensing range [mm] 8 Real sensing range Sr [mm] 8 ± 10 % Operating distance [mm] 0...6.48 Increased sensing range yes Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.7 / brass: 0.5 / aluminium: 0.4 / copper: 0.3 Hysteresis [% of Sr] 1...15 Switch point drift [% of Sr] -10...10 [°C] -40...85 Operating conditions Ambient temperature Protection IP 65; IP 66; IP 67; IP 68 Tests / approvals EMC EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V EN 55011 class B Vibration resistance EN 60068-2-6 Fc 20 g (10...3000 Hz) / 50 sweep cycles, 1 octave per minute, in 3 axes Shock resistance EN 60068-2-27 Ea 100 g 11 ms half-sine; 3 shocks each in every direction of the 3 coordinate axes Continuous shock resistance EN 60068-2-27 40 g 6 ms; 4000 shocks each in every direction of the 3 coordinate axes Fast temperature change EN 60068-2-14 Na TA = -40°C; TB = 85°C; t1 = 30 min; t2 = < 10 s 50 cycles MTTF [years] UL approval 1688 Ta -25...70 °C Enclosure type Type 1 power supply Limited Voltage/Current UL Approval no. A016 File number UL E174191 Mechanical data Weight [g] 42.7 Housing rectangular Mounting flush mountable Dimensions Materials [mm] 20 x 8 x 32 diecast zinc special coating; sensing face: PBT orange; LED window: TPU; potting: PUR ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IQ2002-00 — 13.04.2023 — IQ2002 Inductive sensor IQ23008BBPKG/0.3M/PUR/US Displays / operating elements Display Display operation 1 x LED, green switching status 1 x LED, yellow Remarks Pack quantity 1 pcs. Electrical connection Cable: 0.3 m, PUR, Ø 4.9 mm; 3 x 0.34 mm² Connection Electrical connection - plug Connector: 1 x M12 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IQ2002-00 — 13.04.2023 —
IQ2002 价格&库存
很抱歉,暂时无法提供与“IQ2002”相匹配的价格&库存,您可以联系我们找货
