IS3501
IS3501
    IFM(易福门)
    模块
    INDUCTIVE PROXIMITY SENSOR, 2MM
IS3501 数据手册
IS3501 Inductive sensor IS-2002-AROA/12"K Product characteristics Output function Sensing range normally open [mm] Housing Dimensions 2 rectangular [mm] 28 x 10 x 16 [Hz] 45...65 [V] 20...140 AC / 10...140 DC Electrical data Frequency AC Operating voltage Protection class II Reverse polarity protection no Outputs Output function normally open Max. voltage drop switching output DC [V] Max. voltage drop switching output AC [V] 5 5 Minimum load current [mA] 5 Max. leakage current [mA] 0.8 Permanent current rating of switching output AC [mA] Permanent current rating of switching output DC [mA] Short-time current rating of switching output [mA] Switching frequency AC [Hz] 25 Switching frequency DC [Hz] 25 200 200 900; (20 ms / 0,5 Hz) Short-circuit protection no Overload protection no ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IS3501-00 — 13.04.2023 — IS3501 Inductive sensor IS-2002-AROA/12"K Detection zone Sensing range [mm] 2 Real sensing range Sr [mm] 2 ± 10 % Operating distance [mm] 0...1.6 Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.9 / brass: 0.8 / aluminium: 0.5 / copper: 0.46 Hysteresis [% of Sr] 1...15 Switch point drift [% of Sr] -10...10 [°C] -20...80 Operating conditions Ambient temperature Protection IP 67 Tests / approvals EMC EN 60947-5-2 EN 55011 MTTF [years] class B 1724 Mechanical data Weight [g] 15 Housing rectangular Mounting flush mountable Dimensions [mm] 28 x 10 x 16 Materials Tightening torque PBT [Nm] < 0.5; (with washer) Displays / operating elements Display switching status 1 x LED, red Electrical connection Required protection miniature fuse to IEC60127-2 sheet 1; ≤ 2 A; fast acting Remarks Remarks Pack quantity Recommendation: Check the safe functioning of the unit after a short circuit. 1 pcs. ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IS3501-00 — 13.04.2023 — IS3501 Inductive sensor IS-2002-AROA/12"K Electrical connection Cable: 0.3 m, PVC; 2 x 0.25 mm² Connection BN = BU = Note miniature fuse to IEC60127-2 sheet 1 ≤ 2 A fast acting Core colours : brown blue ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IS3501-00 — 13.04.2023 —
IS3501 价格&库存
很抱歉,暂时无法提供与“IS3501”相匹配的价格&库存,您可以联系我们找货
