IY5048
IY5048
    IFM(易福门)
    圆柱形,有螺纹-M5
    SENSOR PROX INDUCTIVE 1.5MM CYL
IY5048 数据手册
IY5048 Inductive sensor IYB31,5-BPKG/AS-514-TPS Product characteristics Electrical design PNP Output function normally open Sensing range [mm] 1.5 [mm] M5 x 0.5 / L = 41 Housing threaded type Dimensions Electrical data Operating voltage Current consumption [V] 10...30 DC [mA] 10; (24 V) Reverse polarity protection yes Outputs Electrical design PNP Output function normally open Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] Switching frequency DC [Hz] Short-circuit protection 3 100 1800 yes Type of short-circuit protection pulsed Overload protection yes Detection zone Sensing range [mm] 1.5 Real sensing range Sr [mm] 1.5 ± 10 % Operating distance [mm] 0...1.2 Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.7 / brass: 0.4 / aluminium: 0.3 / copper: 0.2 Hysteresis [% of Sr] < 15 Switch point drift [% of Sr] -10...10 [°C] -25...70 Operating conditions Ambient temperature ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IY5048-00 — 06.03.2003 — IY5048 Inductive sensor IYB31,5-BPKG/AS-514-TPS Protection IP 67 Tests / approvals EMC EN 60947-5-2 EN 55011 MTTF [years] UL approval class B 835 Ta 0...40 °C power supply Class 2 File number UL E174191 Mechanical data Weight [g] 15.8 Housing threaded type Mounting non-flush mountable Dimensions [mm] M5 x 0.5 / L = 41 Thread designation M5 x 0.5 Materials housing: stainless steel; sensing face: POM Displays / operating elements Display switching status 4 x 90° LED, red Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M8; coding: A Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IY5048-00 — 06.03.2003 — IY5048 Inductive sensor IYB31,5-BPKG/AS-514-TPS Diagrams and graphs Installation If Sr varies by < 10 % the following free space must be maintained ferromagnetic materials X > 1.5 mm other metals X > 3.0 mm ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IY5048-00 — 06.03.2003 —
IY5048 价格&库存
很抱歉,暂时无法提供与“IY5048”相匹配的价格&库存,您可以联系我们找货
