KI0206
KI0206
    IFM(易福门)
    圆柱形,有螺纹-M30
    CAPACITIVE PROXIMITY SENSOR, 30M
KI0206 数据手册
KI0206 Capacitive sensor KI-2015-ABOA/NI/0,1/LS-100AK Product characteristics Output function Sensing range normally open [mm] Housing 3...15 threaded type Dimensions [mm] M30 x 1.5 Electrical data Operating voltage [V] 20...250 AC/DC Protection class II Reverse polarity protection no Outputs Output function normally open Max. voltage drop switching output DC [V] Max. voltage drop switching output AC [V] 8 10 Minimum load current [mA] 5 Max. leakage current [mA] 2.5 (250 V AC) / 1.7 (110 V AC) / 1.5 (24 V DC) Permanent current rating of switching output AC [mA] Permanent current rating of switching output DC [mA] Short-time current rating of switching output [mA] Switching frequency AC [Hz] 25 Switching frequency DC [Hz] 50 200; (250 (...50 °C)) 200; (250 (...50 °C)) 1500; (20 ms / 0,5 Hz) Short-circuit proof no Overload protection no Detection zone Sensing range [mm] 3...15 Sensing range adjustable yes Factory setting sensing range [mm] 15 Real sensing range Sr [mm] 15 ± 10 % Operating distance [mm] 0...12.1 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — KI0206-00 — 27.10.2011 — KI0206 Capacitive sensor KI-2015-ABOA/NI/0,1/LS-100AK Accuracy / deviations Correction factor glass: 0.4 / water: 1 / ceramics: 0.2 / PVC: 0.2 Hysteresis [% of Sr] 1...15 Switch point drift [% of Sr] -15...15 [°C] -25...70 Operating conditions Ambient temperature Protection IP 65 Increased immunity yes; (increased immunity to conducted radio frequency interference) Tests / approvals EMC EN 60947-5-2 MTTF [years] 302 [g] 126 Mechanical data Weight Housing threaded type Mounting non-flush mountable Dimensions [mm] M30 x 1.5 Thread designation M30 x 1.5 Materials PBT Displays / operating elements Display switching status 1 x LED, yellow Electrical connection Required protection miniature fuse to IEC60127-2 sheet 1; ≤ 2 A; fast acting Accessories Items supplied lock nuts: 2 screwdriver: 1 Remarks Remarks Pack quantity Recommendation: Check the safe functioning of the unit after a short circuit. 1 pcs. ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — KI0206-00 — 27.10.2011 — KI0206 Capacitive sensor KI-2015-ABOA/NI/0,1/LS-100AK Electrical connection - plug Cable: 0.1 m, PVC; 2 x 0.5 mm² Connector: 1 x 1/2"; coding: C Note miniature fuse to IEC60127-2 sheet 1 ≤ 2 A fast acting ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — KI0206-00 — 27.10.2011 —
KI0206 价格&库存
很抱歉,暂时无法提供与“KI0206”相匹配的价格&库存,您可以联系我们找货
