KI5209
KI5209
    IFM(易福门)
    圆柱形,有螺纹-M30
    CAPACITIVE PROXIMITY SENSOR, 30M
KI5209 数据手册
KI5209 Capacitive sensor KI-3015-FPKG/NI/0,10M/PH/US100 Product characteristics Electrical design PNP Output function normally open / normally closed; (selectable) Sensing range [mm] 3...15 [mm] M30 x 1.5 / L = 81 Housing threaded type Dimensions Electrical data Operating voltage [V] Current consumption [mA] Protection class 10...36 DC < 15 II Reverse polarity protection yes Outputs Electrical design PNP Output function normally open / normally closed; (selectable) Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] Short-time current rating of switching output [mA] Switching frequency DC [Hz] 2.5 250 250 40 Short-circuit proof yes Overload protection yes Detection zone Sensing range [mm] 3...15 Sensing range adjustable yes Factory setting sensing range [mm] 15 Real sensing range Sr [mm] 15 ± 10 % Operating distance [mm] 0...12.1 Accuracy / deviations Correction factor Hysteresis glass: 0.4 / water: 1 / ceramics: 0.2 / PVC: 0.2 [% of Sr] 1...15 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — KI5209-00 — 13.04.2023 — KI5209 Capacitive sensor KI-3015-FPKG/NI/0,10M/PH/US100 Switch point drift [% of Sr] -15...15 [°C] -25...80 Operating conditions Ambient temperature Protection IP 65 Tests / approvals MTTF [years] 692 Mechanical data Weight [g] 102.5 Housing threaded type Mounting non-flush mountable Dimensions [mm] M30 x 1.5 / L = 81 Thread designation M30 x 1.5 Materials PBT Displays / operating elements Display switching status 1 x LED, red Accessories Items supplied lock nuts: 2 screwdriver: 1 Remarks Pack quantity 1 pcs. Electrical connection - plug Cable: 0.1 m, PUR Connector: 1 x M12; coding: A ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — KI5209-00 — 13.04.2023 —
KI5209 价格&库存
很抱歉,暂时无法提供与“KI5209”相匹配的价格&库存,您可以联系我们找货
