MGT201
MGT201
    IFM(易福门)
    圆柱形,有螺纹-M18
    数字开关 专用型 PNP-NO 磁阻
MGT201 数据手册
MGT201 Magnetic sensor MGK3100-BPKG/M/V4A/US-104-DPS Product characteristics Electrical design PNP Output function normally open Sensing range [mm] Housing 100; (referred to magnet M 4.0) threaded type Dimensions [mm] M18 x 1 / L = 60 Application Special feature Gold-plated contacts Application pig detection Electrical data Operating voltage [V] Current consumption [mA] Protection class 10...30 DC < 10 III Reverse polarity protection yes Outputs Electrical design PNP Output function normally open Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] 2.5 200 Short-circuit protection yes Overload protection yes Detection zone Sensing range [mm] 100; (referred to magnet M 4.0) Response sensitivity [mT] 0.3 Accuracy / deviations Hysteresis [% of Sr] 1...10 [ms] 1000 Response times Pulse stretching ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — MGT201-00 — 13.04.2023 — MGT201 Magnetic sensor MGK3100-BPKG/M/V4A/US-104-DPS Operating conditions Ambient temperature [°C] 0...104 Protection IP 68; IP 69K Tests / approvals EMC MTTF EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-5 Surge 0,5 kV line to line, Ri: 2 Ohm EN 61000-4-6 HF conducted 10 V EN 55011 class B [years] 769 [g] 47.3 Mechanical data Weight Housing Dimensions threaded type [mm] M18 x 1 / L = 60 Thread designation Materials M18 x 1 housing: stainless steel (1.4404 / 316L); sensing face: PEEK; lock nuts: stainless steel Displays / operating elements Display switching status 1 x LED, yellow Accessories Items supplied lock nuts: 2 Remarks Remarks Pack quantity voltage supply to EN50178, SELV, PELV 1 pcs. Electrical connection - plug Connector: 1 x M12; coding: A; Contacts: gold-plated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — MGT201-00 — 13.04.2023 — MGT201 Magnetic sensor MGK3100-BPKG/M/V4A/US-104-DPS Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — MGT201-00 — 13.04.2023 —
MGT201 价格&库存
很抱歉,暂时无法提供与“MGT201”相匹配的价格&库存,您可以联系我们找货
