MFT202
MFT202
    IFM(易福门)
    圆柱形,有螺纹-M12
    数字开关 专用型 PNP-NO 磁阻
MFT202 数据手册
MFT202 Full-metal magnetic sensor MFK3060-BPKG/AM/V4A/G/US Product characteristics Electrical design PNP Output function normally open Sensing range [mm] 60; (referred to magnet M 4.0) [mm] M12 x 1 / L = 60 Housing threaded type Dimensions Application Special feature Gold-plated contacts; Full-metal housing Pressure rating [bar] 100 Electrical data Operating voltage [V] Current consumption [mA] Protection class 10...30 DC < 10 III Reverse polarity protection yes Outputs Electrical design PNP Output function normally open Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] Switching frequency DC [Hz] 2.5 100 5000 Short-circuit protection yes Overload protection yes Detection zone Sensing range [mm] 60; (referred to magnet M 4.0) Response sensitivity [mT] 1.3 Accuracy / deviations Hysteresis [% of Sr] 1...10 [°C] 0...100 Operating conditions Ambient temperature Protection IP 65; IP 68; IP 69K ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — MFT202-00 — 15.04.2013 — MFT202 Full-metal magnetic sensor MFK3060-BPKG/AM/V4A/G/US Tests / approvals EMC MTTF EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-5 Surge 0,5 kV line to line, Ri: 2 Ohm EN 61000-4-6 HF conducted 10 V EN 55011 class B DIN ISO 11452-2 100 V/m [years] 1401 [g] 28.1 Mechanical data Weight Housing Dimensions threaded type [mm] M12 x 1 / L = 60 Thread designation M12 x 1 Materials housing: stainless steel (1.4404 / 316L); sensing face: stainless steel (1.4404 / 316L); lock nuts: stainless steel Full-metal housing yes Displays / operating elements Display switching status 1 x LED, yellow Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12; coding: A; Contacts: gold-plated Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — MFT202-00 — 15.04.2013 —
MFT202 价格&库存
很抱歉,暂时无法提供与“MFT202”相匹配的价格&库存,您可以联系我们找货
