MK5351
MK5351
    IFM(易福门)
    模块
    数字开关 专用型 PNP-NO
MK5351 数据手册
MK5351 C-slot cylinder sensor MKC3020BBPKG/A/0,3/ZH/US/2X 1 2 3 4 sensor 1 sensor 2 Sensing face fastening clamp Product characteristics Electrical design PNP Output function normally open Dimensions [mm] 26.1 x 2.8 x 5.5 Electrical data Operating voltage Current consumption [V] [mA] Protection class < 10 III Reverse polarity protection Max. power-on delay time 10...30 DC yes [ms] 30 Outputs Electrical design PNP Output function normally open Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] Switching frequency DC [Hz] 2.5 100 5000 Short-circuit protection yes Overload protection yes Detection zone Response sensitivity [mT] 2 Travel speed [m/s] > 10 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — MK5351-00 — 13.04.2023 — MK5351 C-slot cylinder sensor MKC3020BBPKG/A/0,3/ZH/US/2X Accuracy / deviations Hysteresis [mm] 1 Repeatability [mm] < 0.2 [°C] -25...85 Operating conditions Ambient temperature Protection IP 65; IP 67 Tests / approvals EMC EN 61000-4-2 ESD - CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V EN 55011 class B Mechanical data Weight [g] 21.7 Mounting flush mountable Cylinder type C-slot cylinders Dimensions [mm] 26.1 x 2.8 x 5.5 Materials Tightening torque housing: PA; fastening clamp: stainless steel [Nm] < 0.24 Displays / operating elements Display switching status 1 x LED, yellow Remarks Pack quantity 1 pcs. Electrical connection - plug Cable: 0.3 m, PUR Connector: 1 x M12; coding: A; Locking: knurled nut, rotatable ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — MK5351-00 — 13.04.2023 — MK5351 C-slot cylinder sensor MKC3020BBPKG/A/0,3/ZH/US/2X Connection 1: 2: sensor 1 sensor 2 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — MK5351-00 — 13.04.2023 —
MK5351 价格&库存
很抱歉,暂时无法提供与“MK5351”相匹配的价格&库存,您可以联系我们找货
