O1D105
O1D105
    IFM(易福门)
    穿透光束 光学传感器 7.874" ~ 393.701"(200mm ~ 10m) PNP-NC/NO
O1D105 数据手册
O1D105 Photoelectric distance sensor O1DLF3KG/IO-LINK When selecting an alternative article and accessories please note that technical data may differ! 1 2 alphanumeric display 4-digit programming buttons Product characteristics Laser protection class 2 Housing rectangular Electrical data Operating voltage Current consumption [V] [mA] Protection class < 150 III Reverse polarity protection Typ. lifetime 18...30 DC yes [h] 50000 Inputs / outputs Number of inputs and outputs Number of digital outputs: 2; Number of analogue outputs: 1 Outputs Total number of outputs 2 Electrical design PNP Number of digital outputs 2 Output function Max. current load per output Number of analogue outputs normally open / normally closed; (programmable) [mA] 200 1 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O1D105-04 — 11.10.2023 — O1D105 Photoelectric distance sensor O1DLF3KG/IO-LINK Analogue current output [mA] 4...20; (scalable IEC 61131-2) Max. load [Ω] 250 Analogue voltage output [V] 0...10; (scalable IEC 61131-2) Min. load resistance [Ω] 5000 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Detection zone Max. light spot width [mm] Max. light spot height [mm] 15 15 Light spot dimensions refer to Background suppression 10 m [m] 10...100 [m] 0.2...10; (white paper 200 x 200 mm 90% remission) [Hz] 1...33 Measuring/setting range Measuring range Sampling rate Interfaces Communication interface IO-Link Transmission type COM2 (38,4 kBaud) IO-Link revision 1.1 SDCI standard IEC 61131-9 Profiles Smart Sensor: Device Identification; Device Diagnosis; Device Teach Channel; Binary Data Channel; Process Data Variable SIO mode yes Required master port type A Process data analogue 2 Process data binary Min. process cycle time 2 [ms] Supported DeviceIDs 6 Type of operation DeviceID Default 809 Operating conditions Ambient temperature [°C] -10...60 Protection IP 67 Tests / approvals EMC EN 60947-5-2 Laser protection class 2 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O1D105-04 — 11.10.2023 — O1D105 Photoelectric distance sensor O1DLF3KG/IO-LINK Notes on laser protection Caution: laser light Power:
O1D105 价格&库存
很抱歉,暂时无法提供与“O1D105”相匹配的价格&库存,您可以联系我们找货
O1D105
    • 1+4193.724201+543.58650
    库存:1
    O1D105
    • 1+3509.87964
    库存:12
