OGH200
OGH200
    IFM(易福门)
    扩散 光学传感器 3.937"(100mm) PNP - 亮通
OGH200 数据手册
OGH200 Diffuse reflection sensor with background suppression OGH-HPKG/US100 1 potentiometer Product characteristics Type of light red light Housing threaded type Application Special feature Background suppression Function principle Diffuse reflection sensor Electrical data Operating voltage Current consumption [V] [mA] Protection class 25 II Reverse polarity protection yes Type of light Wave length 10...36 DC red light [nm] 624 Outputs Electrical design PNP Output function light-on mode Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] Switching frequency DC [Hz] Short-circuit protection 2.5 200 1000 yes Type of short-circuit protection pulsed Overload protection yes Detection zone Range [mm] 15...250; (white paper 200 x 200 mm 90% remission) Range on white object (90 % [mm] remission) 15...250 Range on grey object (18 % remission) 15...230 [mm] ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGH200-01 — 13.04.2023 — OGH200 Diffuse reflection sensor with background suppression OGH-HPKG/US100 Range on black object (6 % remission) [mm] 15...160 Range adjustable yes Max. light spot diameter [mm] 21 Light spot dimensions refer to at maximum range Background suppression available yes Operating conditions Ambient temperature [°C] -25...60 Protection IP 65 Tests / approvals EMC EN 60947-5-2 MTTF [years] 339 [g] 53.1 Mechanical data Weight Housing Dimensions threaded type [mm] M18 x 1 / L = 72 Thread designation M18 x 1 Materials housing: stainless steel; operator interface: TPE Lens material PMMA Displays / operating elements Display switching status Operating elements 1 x LED, yellow potentiometer Accessories Items supplied lock nuts: 2 Remarks Remarks Pack quantity operating voltage "supply class 2" according to cULus 1 pcs. Electrical connection Connector: 1 x M12; coding: A ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGH200-01 — 13.04.2023 — OGH200 Diffuse reflection sensor with background suppression OGH-HPKG/US100 Connection Diagrams and graphs a: sensor b: object c: background x: distance sensor/object [mm] y: min. distance object/background [mm] ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGH200-01 — 13.04.2023 — OGH200 Diffuse reflection sensor with background suppression OGH-HPKG/US100 accuracy graph x: distance sensor/object [mm] y: min. distance object/background [mm] 1 = object black (6 % remission) , background white (90 % remission) 2 = object grey (18 % remission) , background white (90 % remission) 3 = object white (90 % remission) , background white (90 % remission) ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGH200-01 — 13.04.2023 —
OGH200 价格&库存
很抱歉,暂时无法提供与“OGH200”相匹配的价格&库存,您可以联系我们找货
OGH200
    • 1+1363.504531+176.95800
