OGP200
OGP200
    IFM(易福门)
    回射 光学传感器 15.748"(400mm) PNP - 暗光
OGP200 数据手册
OGP200 Retro-reflective sensor OGP-DPKG/US100 Product characteristics Type of light red light Housing threaded type Application Special feature polarisation filter Function principle Retro-reflective sensor Electrical data Operating voltage Current consumption [V] [mA] Protection class 15 II Reverse polarity protection yes Type of light Wave length 10...36 DC red light [nm] 624 Outputs Electrical design PNP Output function dark-on mode Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] Switching frequency DC [Hz] Short-circuit protection 2.5 200 1000 yes Type of short-circuit protection pulsed Overload protection yes Detection zone Range referred to prismatic reflector [m] Range adjustable Max. light spot diameter Light spot dimensions refer to 0.03...4; (Prismatic reflector Ø 80 E20005) no [mm] 160 at maximum range ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGP200-00 — 13.04.2023 — OGP200 Retro-reflective sensor OGP-DPKG/US100 Polarisation filter available yes Operating conditions Ambient temperature [°C] -25...60 Protection IP 67 Tests / approvals EMC EN 60947-5-2 MTTF [years] 509 Mechanical data Weight [g] 49.75 Housing Dimensions threaded type [mm] M18 x 1 / L = 60 Thread designation M18 x 1 Materials housing: stainless steel (1.4404 / 316L) Lens material PMMA Displays / operating elements Display switching status 1 x LED, yellow Accessories Items supplied lock nuts: 2 Remarks Remarks Pack quantity operating voltage "supply class 2" according to cULus 1 pcs. Electrical connection Connector: 1 x M12; coding: A Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGP200-00 — 13.04.2023 — OGP200 Retro-reflective sensor OGP-DPKG/US100 Diagrams and graphs excess gain graph ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGP200-00 — 13.04.2023 —
OGP200
物料型号:OGP200
器件简介: - 类型:Retro-reflective sensor(反射式传感器) - 光源类型:红光 - 外壳类型:螺纹型 - 特殊功能:偏振滤波器
引脚分配:文档中未提供引脚分配信息。
参数特性: - 工作电压:10...36V DC - 电流消耗:15mA - 保护等级:II - 防反接保护:是 - 光源类型:红光 - 波长:624nm - 输出类型:PNP - 输出功能:暗态模式 - 最大电压降:2.5V DC - 开关输出的持续电流:200mA - 开关频率:1000Hz - 短路保护:是 - 过载保护:是
功能详解: - 检测区域:针对棱镜反射器的范围是0.03...4米 - 光斑直径最大:160mm
应用信息: - 环境温度:-25...60°C - 保护:IP67 - EMC:EN60947-5-2 - MTTF(平均无故障时间):509年
封装信息: - 重量:49.75g - 外壳材料:不锈钢(1.4404 / 316L) - 螺纹规格:M18x1 - 镜头材料:PMMA(聚甲基丙烯酸甲酯) - 显示/操作元件:1个黄色状态指示LED - 配件:2个锁紧螺母
OGP200 价格&库存
很抱歉,暂时无法提供与“OGP200”相匹配的价格&库存,您可以联系我们找货
