PA3024
PA3024
    IFM(易福门)
    圆柱形,有螺纹
    PRESSURE TRANSMITTER,0-10 BAR,AN
PA3024 数据手册
PA3024 Pressure transmitter with ceramic measuring cell PA-010-RBR14-A-ZVG/US/ /V When selecting an alternative article and accessories please note that technical data may differ! Product characteristics Number of inputs and outputs Number of analogue outputs: 1 Measuring range 0...10 bar Process connection 0...145 psi 0...1000 kPa 0...1 MPa threaded connection G 1/4 internal thread Application Special feature Gold-plated contacts Application for industrial applications Media liquids and gases Medium temperature [°C] -25...90; (on request: -40...90 °C) Min. bursting pressure 150 bar 2175 psi 15 MPa Pressure rating 75 bar 1088 psi 7.5 Mpa Type of pressure relative pressure Electrical data Operating voltage Min. insulation resistance Protection class Reverse polarity protection [V] [MΩ] 9.6...32 DC 100; (500 V DC) III yes Inputs / outputs Number of inputs and outputs Number of analogue outputs: 1 Outputs Total number of outputs Output signal Number of analogue outputs 1 analogue signal 1 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PA3024-01 — 13.04.2023 — PA3024 Pressure transmitter with ceramic measuring cell PA-010-RBR14-A-ZVG/US/ /V Analogue current output [mA] Max. load 4...20 [Ω] 720; (Ub = 24 V; (Ub - 9,6 V) / 20 mA) Overload protection yes Measuring/setting range Measuring range 0...10 bar 0...145 psi 0...1000 kPa 0...1 MPa Accuracy / deviations Repeatability [% of the span] Characteristics deviation [% of the span] < 0,1; (with temperature fluctuations < 10 K) < ± 0,25 (BFSL) / < ± 0,5 (LS); (BFSL = Best Fit Straight Line; LS = limit value setting) Long-term stability < ± 0,05; (per 6 months) [% of the span] Temperature coefficient zero point [% of the span / 10 K] 0,1; (0...80 °C) Temperature coefficient span [% of the span / 10 K] 0,2; (0...80 °C) Response times Step response time analogue output [ms] 3 Operating conditions Ambient temperature [°C] -25...80 Storage temperature [°C] -40...100 Protection IP 65 Tests / approvals EMC EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 30 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V radiation of interference according to the automotive directive 2004/104/EC CISPR 25 Shock resistance Vibration resistance MTTF immunity according to the automotive directive 2004/104/EC ISO 11452-2 HF radiated 100 V/m ISO 7637-2 pulse severity level 4 DIN EN 60068-2-27 50 g (11 ms) DIN EN 61373 category 3 DIN EN 60068-2-6 20 g (10...2000 Hz) DIN EN 61373 category 2 [years] Pressure Equipment Directive 506 Sound engineering practice; can be used for group 2 fluids; group 1 fluids on request Railway applications DIN EN 50155 / IEC 60571 Klasse T3, C1, S1 Mechanical data Weight [g] Materials Materials (wetted parts) Min. pressure cycles 226 stainless steel (1.4404 / 316L); FKM; PA; EPDM/X stainless steel (1.4305 / 303); ceramics; FKM 100 million ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PA3024-01 — 13.04.2023 — PA3024 Pressure transmitter with ceramic measuring cell PA-010-RBR14-A-ZVG/US/ /V Process connection Restrictor element integrated threaded connection G 1/4 internal thread no (can be retrofitted) Remarks Pack quantity 1 pcs. Electrical connection Connector: 1 x M12; coding: A; Contacts: gold-plated Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PA3024-01 — 13.04.2023 —
PA3024 价格&库存
很抱歉,暂时无法提供与“PA3024”相匹配的价格&库存,您可以联系我们找货
