PN2596
PN2596
    IFM(易福门)
    ELECTRONIC PRESSURE SENSOR; -0.1
PN2596 数据手册
PN2596 Pressure sensor with display PN-2,5-REG14-MFRKG/US/ /V 1 2 3 4 5 alphanumeric display 4-digit red/green LEDs Display unit / switching status programming button upper part of the housing can be rotated 345° Sealing Product characteristics Number of inputs and outputs Number of digital outputs: 2; Number of analogue outputs: 1 Measuring range -0.125...2.5 bar Process connection -125...2500 mbar -1.8...36.25 psi -12.5...250 kPa threaded connection G 1/4 external thread (DIN EN ISO 1179-2); internal thread:M5 Application Special feature Gold-plated contacts Measuring element ceramic-capacitive pressure measuring cell Application for industrial applications Media liquids and gases Medium temperature [°C] -25...80 Min. bursting pressure 50 bar 725 psi 5000 kPa Pressure rating 20 bar 290 psi 2000 kPa Vacuum resistance [mbar] Type of pressure -1000 relative pressure Electrical data Operating voltage [V] 18...30 DC; (to SELV/PELV) Current consumption [mA] < 35 Min. insulation resistance [MΩ] 100; (500 V DC) Protection class Reverse polarity protection III yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PN2596-00 — 13.04.2023 — PN2596 Pressure sensor with display PN-2,5-REG14-MFRKG/US/ /V Power-on delay time [s] 0.3 Integrated watchdog yes Inputs / outputs Number of inputs and outputs Number of digital outputs: 2; Number of analogue outputs: 1 Outputs Total number of outputs 2 Output signal switching signal; analogue signal; IO-Link; (configurable) Electrical design PNP/NPN Number of digital outputs 2 Output function normally open / normally closed; (parameterisable) Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] Switching frequency DC [Hz] 2 250 < 500 Number of analogue outputs Analogue current output 1 [mA] 4...20; (scalable 1:5) Max. load [Ω] 500 Analogue voltage output [V] 0...10; (scalable 1:5) Min. load resistance [Ω] 2000 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Measuring/setting range Measuring range -0.125...2.5 bar -125...2500 mbar -1.8...36.25 psi -12.5...250 kPa Set point SP -0.11...2.5 bar -1.6...36.25 psi -11...250 kPa Reset point rP -0.12...2.49 bar -1.75...36.1 psi -12...249 kPa Analogue start point -0.125...2 bar -1.8...29 psi -12.5...200 kPa Analogue end point 0.375...2.5 bar 5.45...36.25 psi 37.5...250 kPa In steps of 0.005 bar 0.05 psi 0.5 kPa Accuracy / deviations Switch point accuracy [% of the span] Repeatability [% of the span] Characteristics deviation [% of the span] Hysteresis deviation [% of the span] Long-term stability [% of the span] < ± 0,4; (Turn down 1:1) < ± 0,1; (with temperature fluctuations < 10 K; Turn down 1:1) < ± 0,25 (BFSL) / < ± 0,5 (LS); (Turn down 1:1; BFSL = Best Fit Straight Line; LS = limit value setting) < ± 0,1; (Turn down 1:1) < ± 0,05; (Turn down 1:1; per 6 months) Temperature coefficient zero point [% of the span / 10 K] < ± 0,2; (-0...80 °C) Temperature coefficient span [% of the span / 10 K] < ± 0,2; (-0...80 °C) ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PN2596-00 — 13.04.2023 — PN2596 Pressure sensor with display PN-2,5-REG14-MFRKG/US/ /V Notes on the accuracy / deviation switch point accuracy, linearity error under DNV GL: < ± 1%: < ± 1% Response times Response time [ms] Delay time programmable dS, dr [s] Damping process value dAP [s] Damping for the analogue output dAA [s] < 1.5 0...50 0...4 0...4 Max. response time analogue [ms] output 3 Software / programming Parameter setting options hysteresis / window; normally open / normally closed; switch-on/ switch-off delay; Damping; Display unit; current/voltage output Interfaces Communication interface IO-Link Transmission type COM2 (38,4 kBaud) IO-Link revision 1.1 SDCI standard IEC 61131-9 Profiles Smart Sensor: Process Data Variable; Device Identification, Device Diagnosis SIO mode yes Required master port type A Process data analogue 1 Process data binary 2 Min. process cycle time [ms] Supported DeviceIDs 2.3 Type of operation DeviceID Default 464 Operating conditions Ambient temperature [°C] -25...80 Storage temperature [°C] -40...100 Protection IP 65; IP 67 Tests / approvals EMC DIN EN 61000-6-2 DIN EN 61000-6-3 Shock resistance Vibration resistance MTTF DIN EN 60068-2-27 50 g (11 ms) DIN EN 60068-2-6 20 g (10...2000 Hz) [years] UL approval 138 UL Approval no. Pressure Equipment Directive J012 Sound engineering practice; can be used for group 2 fluids; group 1 fluids on request Mechanical data Weight [g] Materials stainless steel (1.4404 / 316L); PBT+PC-GF30; PBT-GF20; PC Materials (wetted parts) stainless steel (1.4404 / 316L); AI2O3 (96%; ceramics); FKM Min. pressure cycles Tightening torque Process connection 263 100 million [Nm] 25...35; (recommended tightening torque; depends on lubrication, seal and pressure rating) threaded connection G 1/4 external thread (DIN EN ISO 1179-2); internal thread:M5 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PN2596-00 — 13.04.2023 — PN2596 Pressure sensor with display PN-2,5-REG14-MFRKG/US/ /V Process connection sealing FKM (DIN EN ISO 1179-2) Restrictor element integrated no (can be retrofitted) Displays / operating elements Display Display unit 3 x LED, green (bar, psi, MPa) switching status 2 x LED, yellow measured values alphanumeric display, red/green 4-digit Remarks Pack quantity 1 pcs. Electrical connection Connector: 1 x M12; coding: A; Contacts: gold-plated Connection OUT1 OUT2 BK = BN = BU = WH = switching output IO-Link switching output analogue output Core colours : black brown blue white ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PN2596-00 — 13.04.2023 —
PN2596 价格&库存
很抱歉,暂时无法提供与“PN2596”相匹配的价格&库存,您可以联系我们找货
