PN2670
PN2670
    IFM(易福门)
    圆柱形,有螺纹
    PRESSURE SENSOR, 4WIRE DC, 2X PN
PN2670 数据手册
PN2670 Pressure sensor with display PN-400-SEN14-MFRKG/US/ /V 1 2 3 4 alphanumeric display 4-digit red/green LEDs Display unit / switching status programming button upper part of the housing can be rotated 345° Product characteristics Number of inputs and outputs Number of digital outputs: 2; Number of analogue outputs: 1 Measuring range 0...400 bar Process connection 0...5800 psi 0...40 MPa threaded connection 1/4" NPT external thread Application Special feature Gold-plated contacts Measuring element metallic thin film cell Application for industrial applications Media liquids and gases Medium temperature [°C] Min. bursting pressure Pressure rating Vacuum resistance -25...80 1700 bar 24650 psi 800 bar 11580 psi [mbar] 170 MPa 80 Mpa -1000 Type of pressure relative pressure MAWP (for applications according to CRN) 800 bar 11580 psi 80 MPa Electrical data Operating voltage [V] 18...30 DC; (to SELV/PELV) Current consumption [mA] < 35 Min. insulation resistance [MΩ] 100; (500 V DC) Protection class III ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PN2670-01 — 13.04.2023 — PN2670 Pressure sensor with display PN-400-SEN14-MFRKG/US/ /V Reverse polarity protection Power-on delay time yes [s] 0.3 Integrated watchdog yes Inputs / outputs Number of inputs and outputs Number of digital outputs: 2; Number of analogue outputs: 1 Outputs Total number of outputs 2 Output signal switching signal; analogue signal; IO-Link; (configurable) Electrical design PNP/NPN Number of digital outputs 2 Output function normally open / normally closed; (parameterisable) Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] Switching frequency DC [Hz] 2 250 < 500 Number of analogue outputs Analogue current output 1 [mA] 4...20; (scalable 1:5) Max. load [Ω] 500 Analogue voltage output [V] 0...10; (scalable 1:5) Min. load resistance [Ω] 2000 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Measuring/setting range Measuring range 0...400 bar 0...5800 psi 0...40 MPa Analogue start point 0...320 bar 0...4640 psi 0...32 MPa Analogue end point 80...400 bar 1160...5800 psi 8...40 MPa Set point SP 2.5...400 bar 40...5800 psi 0.25...40 MPa Reset point rP 1...398.5 bar 10...5780 psi 0.1...39.85 MPa Min. difference between SP and rP 2 bar 30 psi 0.2 MPa In steps of 0.5 bar 10 psi 0.05 MPa Set point SP 2.5...400 bar 37...5802 psi 0.25...40 MPa Reset point rP 0.9...398.4 bar 13...5778 psi 0.09...39.84 MPa Min. difference between SP and rP 1.7 bar 24 psi 0.17 MPa In steps of 0.1 bar 1 psi 0.01 MPa Factory setting / CMPT = 2 Status_B High Resolution / CMPT = 3 Accuracy / deviations Switch point accuracy [% of the span] Repeatability [% of the span] Characteristics deviation < ± 0,4; (Turn down 1:1) < ± 0,1; (with temperature fluctuations < 10 K; Turn down 1:1) < ± 0,25 (BFSL) / < ± 0,5 (LS); (Turn down 1:1; BFSL = Best Fit Straight Line; LS = limit value setting) ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PN2670-01 — 13.04.2023 — PN2670 Pressure sensor with display PN-400-SEN14-MFRKG/US/ /V [% of the span] Hysteresis deviation < ± 0,1; (Turn down 1:1) [% of the span] Long-term stability < ± 0,05; (Turn down 1:1; per 6 months) [% of the span] Temperature coefficient zero point [% of the span / 10 K] 0,2; (-25...80 °C) Temperature coefficient span [% of the span / 10 K] 0,2; (-25...80 °C) Notes on the accuracy / deviation switch point accuracy, linearity error under DNV GL: < ± 1%: < ± 1% Response times Response time [ms] Delay time programmable dS, dr [s] Damping process value dAP [s] Damping for the analogue output dAA [s] < 1.5 0...50 0...4 0...4 Max. response time analogue [ms] output 3 Software / programming Parameter setting options hysteresis / window; normally open / normally closed; switch-on/ switch-off delay; Damping; Display unit; current/voltage output Interfaces Communication interface IO-Link Transmission type COM2 (38,4 kBaud) IO-Link revision 1.1 SDCI standard IEC 61131-9 SIO mode yes Required master port type A; (when pin 2 not connected: B) Supported DeviceIDs Type of operation DeviceID Factory setting / CMPT = 2 459 Status_B High Resolution / CMPT = 3 638 Note For further information please see the IODD PDF file under "Downloads" Factory setting / CMPT = 2 Profiles Smart Sensor: Process Data Variable; Device Identification, Device Diagnosis Min. process cycle time [ms] 2.3 IO-Link resolution pressure [bar] 0.1 IO-Link process data (cyclical) function bit length pressure 14 binary switching information IO-Link functions (acyclical) 2 application specific tag Status_B High Resolution / CMPT = 3 Profiles Smart Sensor ED2: Digital Measuring Sensor (0x000A), Identification and Diagnosis (0x4000) Min. process cycle time [ms] 3 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PN2670-01 — 13.04.2023 — PN2670 Pressure sensor with display PN-400-SEN14-MFRKG/US/ /V IO-Link resolution pressure [bar] IO-Link process data (cyclical) 0.2 function bit length pressure 16 device status 4 binary switching information 2 IO-Link functions (acyclical) application specific tag Operating conditions Ambient temperature [°C] -25...80 Storage temperature [°C] -40...100 Protection IP 65; IP 67 Tests / approvals EMC DIN EN 61000-6-2 DIN EN 61000-6-3 Shock resistance DIN EN 60068-2-27 Vibration resistance MTTF DIN EN 60068-2-6 [years] UL approval 20 g (10...2000 Hz) 129 UL Approval no. Pressure Equipment Directive 50 g (11 ms) J014 Sound engineering practice; can be used for group 2 fluids; group 1 fluids on request Mechanical data Weight [g] Materials 242.5 1.4542 (17-4 PH / 630); stainless steel (1.4404 / 316L); PBT+PC-GF30; PBT-GF20; PC Materials (wetted parts) 1.4542 (17-4 PH / 630) Min. pressure cycles Tightening torque 100 million [Nm] > 50; (depends on lubrication, seal and pressure rating) Process connection threaded connection 1/4" NPT external thread Restrictor element integrated no (can be retrofitted) Displays / operating elements Display Display unit 3 x LED, green (bar, psi, MPa) switching status 2 x LED, yellow measured values alphanumeric display, red/green 4-digit Remarks Pack quantity 1 pcs. Electrical connection Connector: 1 x M12; coding: A; Contacts: gold-plated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PN2670-01 — 13.04.2023 — PN2670 Pressure sensor with display PN-400-SEN14-MFRKG/US/ /V Connection OUT1 OUT2 BK = BN = BU = WH = switching output IO-Link switching output analogue output Core colours : black brown blue white ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PN2670-01 — 13.04.2023 —
PN2670 价格&库存
很抱歉,暂时无法提供与“PN2670”相匹配的价格&库存,您可以联系我们找货
