PN2297
PN2297
    IFM(易福门)
    圆柱形,有螺纹
    PRESSURE SENSOR, 4WIRE DC, 2X PN
PN2297 数据手册
PN2297 Pressure sensor with display PN-001BREN14-MFRKG/US/ /V 1 2 3 4 alphanumeric display 4-digit red/green LEDs Display unit / switching status programming button upper part of the housing can be rotated 345° Product characteristics Number of inputs and outputs Number of digital outputs: 2; Number of analogue outputs: 1 Measuring range -0.05...1 bar Process connection -50...1000 mbar -0.72...14.5 psi -20.1...401.5 inH2O -5...100 kPa threaded connection 1/4" NPT internal thread Application Special feature Gold-plated contacts Measuring element ceramic-capacitive pressure measuring cell Application for industrial applications Media liquids and gases Medium temperature [°C] Min. bursting pressure Pressure rating Vacuum resistance -25...80 30000 mbar 450 psi 10000 mbar 145 psi [mbar] 3000 kPa 1000 kPa -1000 Type of pressure relative pressure MAWP (for applications according to CRN) 10 bar 10000 mbar 145 psi 1000 kPa Electrical data Operating voltage [V] 18...30 DC; (to SELV/PELV) Current consumption [mA] < 35 Min. insulation resistance [MΩ] 100; (500 V DC) ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PN2297-01 — 13.04.2023 — PN2297 Pressure sensor with display PN-001BREN14-MFRKG/US/ /V Protection class III Reverse polarity protection Power-on delay time yes [s] 0.3 Integrated watchdog yes Inputs / outputs Number of inputs and outputs Number of digital outputs: 2; Number of analogue outputs: 1 Outputs Total number of outputs 2 Output signal switching signal; analogue signal; IO-Link; (configurable) Electrical design PNP/NPN Number of digital outputs 2 Output function normally open / normally closed; (parameterisable) Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] Switching frequency DC [Hz] 2 250 < 500 Number of analogue outputs Analogue current output 1 [mA] 4...20; (scalable 1:5) Max. load [Ω] 500 Analogue voltage output [V] 0...10; (scalable 1:5) Min. load resistance [Ω] 2000 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Measuring/setting range Measuring range -0.05...1 bar -50...1000 mbar -0.72...14.5 psi -20.1...401.5 inH2O -5...100 kPa Analogue start point -50...800 mbar -0.72...11.6 psi -20...321 inH2O -5...80 kPa Analogue end point 150...1000 mbar 2.18...14.5 psi 60.5...401.5 inH2O 15...100 kPa Set point SP -44...1000 mbar -0.64...14.5 psi -17.5...401.5 inH2O -4.4...100 kPa Reset point rP -48...996 mbar -0.7...14.44 psi -19...400 inH2O -4.4...99.6 kPa Min. difference between SP and rP 6 mbar 0.06 psi 2 inH2O 0.6 kPa In steps of 2 mbar 0.02 psi 0.5 inH2O 0.2 kPa Set point SP -44...1000 mbar -0.63...14.5 psi -17.5...401.5 inH2O -4.4...100 kPa Reset point rP -48...996 mbar -0.69...14.44 psi -19.2...399.8 inH2O -4.8...99.6 kPa Min. difference between SP and rP 5 mbar 0.06 psi 1.7 inH2O 0.5 kPa In steps of 1 mbar 0.01 psi 0.1 inH2O 0.1 kPa Factory setting / CMPT = 2 Status_B High Resolution / CMPT = 3 Accuracy / deviations Switch point accuracy [% of the span] < ± 0,4; (Turn down 1:1) ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PN2297-01 — 13.04.2023 — PN2297 Pressure sensor with display PN-001BREN14-MFRKG/US/ /V Repeatability [% of the span] < ± 0,1; (with temperature fluctuations < 10 K; Turn down 1:1) Characteristics deviation [% of the span] < ± 0,25 (BFSL) / < ± 0,5 (LS); (Turn down 1:1; BFSL = Best Fit Straight Line; LS = limit value setting) Hysteresis deviation < ± 0,1; (Turn down 1:1) [% of the span] Long-term stability < ± 0,05; (Turn down 1:1; per 6 months) [% of the span] Temperature coefficient zero point [% of the span / 10 K] < ± 0,2; (-0...80 °C) Temperature coefficient span [% of the span / 10 K] < ± 0,2; (-0...80 °C) Notes on the accuracy / deviation switch point accuracy, linearity error under DNV GL: < ± 1%: < ± 1% Response times Response time [ms] Delay time programmable dS, dr [s] Damping process value dAP [s] Damping for the analogue output dAA [s] < 1.5 0...50 0...4 0...4 Max. response time analogue [ms] output 3 Software / programming Parameter setting options hysteresis / window; normally open / normally closed; switch-on/ switch-off delay; Damping; Display unit; current/voltage output Interfaces Communication interface IO-Link Transmission type COM2 (38,4 kBaud) IO-Link revision 1.1 SDCI standard IEC 61131-9 SIO mode yes Required master port type A; (when pin 2 not connected: B) Supported DeviceIDs Type of operation DeviceID Factory setting / CMPT = 2 475 Status_B High Resolution / CMPT = 3 991 Note For further information please see the IODD PDF file under "Downloads" Factory setting / CMPT = 2 Profiles Smart Sensor: Process Data Variable; Device Identification, Device Diagnosis Min. process cycle time IO-Link resolution pressure IO-Link process data (cyclical) IO-Link functions (acyclical) [ms] 2.3 [mbar] 1 function bit length pressure 14 binary switching information 2 application specific tag ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PN2297-01 — 13.04.2023 — PN2297 Pressure sensor with display PN-001BREN14-MFRKG/US/ /V Status_B High Resolution / CMPT = 3 Profiles Smart Sensor ED2: Digital Measuring Sensor (0x000A), Identification and Diagnosis (0x4000) Min. process cycle time IO-Link resolution pressure [ms] 3 [mbar] IO-Link process data (cyclical) 0.5 function bit length pressure 16 device status 4 binary switching information 2 IO-Link functions (acyclical) application specific tag Operating conditions Ambient temperature [°C] -25...80 Storage temperature [°C] -40...100 Protection IP 65; IP 67 Tests / approvals EMC DIN EN 61000-6-2 DIN EN 61000-6-3 Shock resistance DIN EN 60068-2-27 50 g (11 ms) Vibration resistance DIN EN 60068-2-6 20 g (10...2000 Hz) MTTF [years] UL approval 138 UL Approval no. Pressure Equipment Directive J012 Sound engineering practice; can be used for group 2 fluids; group 1 fluids on request Mechanical data Weight [g] 222 Materials stainless steel (1.4404 / 316L); PBT+PC-GF30; PBT-GF20; PC Materials (wetted parts) stainless steel (1.4404 / 316L); AI2O3 (96%; ceramics); FKM Min. pressure cycles Tightening torque 100 million [Nm] > 50; (depends on lubrication, seal and pressure rating) Process connection threaded connection 1/4" NPT internal thread Restrictor element integrated no (can be retrofitted) Displays / operating elements Display Display unit 4 x LED, green (mbar, kPa, psi, inH2O) switching status 2 x LED, yellow measured values alphanumeric display, red/green 4-digit Remarks Pack quantity 1 pcs. Electrical connection Connector: 1 x M12; coding: A; Contacts: gold-plated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PN2297-01 — 13.04.2023 — PN2297 Pressure sensor with display PN-001BREN14-MFRKG/US/ /V Connection OUT1 OUT2 BK = BN = BU = WH = switching output IO-Link switching output analogue output Core colours : black brown blue white ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PN2297-01 — 13.04.2023 —
PN2297 价格&库存
很抱歉,暂时无法提供与“PN2297”相匹配的价格&库存,您可以联系我们找货
