PT2415
PT2415
    IFM(易福门)
    圆柱形,有螺纹
    PRESSURE TRANSMITTER, 2WIRE DC,
PT2415 数据手册
PT2415 Pressure transmitter PT-010PSEN14-A-ZVG/US/ /W Product characteristics Number of inputs and outputs Measuring range Number of analogue outputs: 1 [psi] Process connection 0...100 threaded connection 1/4" NPT external thread Application Application for industrial applications Media liquids and gases Medium temperature [°C] -40...90 Min. bursting pressure [psi] 2900 Pressure rating [psi] 250 Note on pressure rating Vacuum resistance static [psi] Type of pressure MAWP (for applications according to CRN) -14.5 relative pressure [psi] 250 Electrical data Operating voltage Min. insulation resistance [V] [MΩ] Protection class 100; (500 V DC) III Reverse polarity protection Power-on delay time 8.5...36 DC yes [s] < 0.1 Inputs / outputs Number of inputs and outputs Number of analogue outputs: 1 Outputs Total number of outputs Output signal 1 analogue signal ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PT2415-00 — 13.04.2023 — PT2415 Pressure transmitter PT-010PSEN14-A-ZVG/US/ /W Number of analogue outputs 1 Analogue current output [mA] Max. load [Ω] 4...20 (Ub – 8,5 V) / 21,5 mA; @8,5V= 0 Ω; @12V max. 160 Ω; @24V max. 720 Ω Short-circuit proof yes Overload protection yes Measuring/setting range Measuring range [psi] 0...100 Accuracy / deviations Repeatability [% of the span] Characteristics deviation [% of the span] < ± 0,05; (with temperature fluctuations < 10 K) < ± 0,5; (incl. drift when overtightened, zero point and span error, non-linearity, hysteresis) Linearity deviation < ± 0,1 (BFSL) / < ± 0,2 (LS) [% of the span] Hysteresis deviation < ± 0,2 [% of the span] Long-term stability < ± 0,1; (per 6 months) [% of the span] Temperature coefficient zero point and span [% of the span / 10 K] < 0,1 (-25...90 °C) / < 0,2 (-40...-25 °C) Response times Step response time analogue output [ms] 1 Operating conditions Ambient temperature [°C] -40...90 Storage temperature [°C] -40...100 Protection IP 67; IP 69K Tests / approvals EMC DIN EN 61000-6-2 DIN EN 61000-6-3 Shock resistance DIN EN 60068-2-27 Vibration resistance MTTF DIN EN 60068-2-6 [years] Pressure Equipment Directive 50 g (11 ms) 20 g (10...2000 Hz) 784 Sound engineering practice; can be used for group 2 fluids; group 1 fluids on request Mechanical data Weight [g] Materials 1.4542 (17-4 PH / 630); stainless steel (1.4404 / 316L); PEI Materials (wetted parts) 1.4542 (17-4 PH / 630) Min. pressure cycles Tightening torque Process connection Restrictor element integrated 57.5 60 million; (at 1.2 times nominal pressure) [Nm] < 50; (recommended tightening torque; depends on lubrication, seal and pressure rating) threaded connection 1/4" NPT external thread no (can be retrofitted) Remarks Remarks BFSL = Best Fit Straight Line LS = limit value setting ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PT2415-00 — 13.04.2023 — PT2415 Pressure transmitter PT-010PSEN14-A-ZVG/US/ /W Pack quantity 1 pcs. Electrical connection Connector: 1 x M12; coding: A Connection OUT BN = WH = analogue output colours to DIN EN 60947-5-2 Core colours : brown white ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PT2415-00 — 13.04.2023 —
PT2415 价格&库存
很抱歉,暂时无法提供与“PT2415”相匹配的价格&库存,您可以联系我们找货
