PX3244
PX3244
    IFM(易福门)
    圆柱形,有螺纹
    PRESSURE TRANSMITTER, 2WIRE DC,
PX3244 数据手册
PX3244 Pressure transmitter with ceramic measuring cell PA-015PRBN14-A-ZVG/US/ 1 /V ventilation Product characteristics Number of inputs and outputs Measuring range Number of analogue outputs: 1 [psi] Process connection 0...150 threaded connection 1/4" NPT external thread internal thread:M5 Application Special feature Gold-plated contacts Application for industrial applications Media liquids and gases Medium temperature [°C] -25...90 Min. bursting pressure [psi] 2175 Pressure rating [psi] 1087 Type of pressure relative pressure Electrical data Operating voltage Min. insulation resistance Protection class Reverse polarity protection [V] [MΩ] 9.6...32 DC 100; (500 V DC) III yes Inputs / outputs Number of inputs and outputs Number of analogue outputs: 1 Outputs Total number of outputs Output signal Number of analogue outputs 1 analogue signal 1 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PX3244-00 — 13.04.2023 — PX3244 Pressure transmitter with ceramic measuring cell PA-015PRBN14-A-ZVG/US/ /V Analogue current output [mA] Max. load 4...20 [Ω] 720; (Ub = 24 V; (Ub - 9,6 V) / 20 mA) Overload protection yes Measuring/setting range Measuring range [psi] 0...150 Accuracy / deviations Repeatability [% of the span] Characteristics deviation [% of the span] < 0,15; (with temperature fluctuations < 10 K) < ± 0,35 (BFSL) / < ± 0,75 (LS); (incl. linearity, zero and span error (limit value setting)) Long-term stability < ± 0,05; (per 6 months) [% of the span] Temperature coefficient zero point [% of the span / 10 K] 0,2; (0...80 °C) Temperature coefficient span [% of the span / 10 K] 0,3; (0...80 °C) Response times Step response time analogue output [ms] 3 Operating conditions Ambient temperature [°C] -25...80 Storage temperature [°C] -40...100 Protection IP 65 Tests / approvals EMC EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 30 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V radiation of interference according to the automotive directive 2004/104/EC / CISPR 25 immunity according to the automotive directive 2004/104/EC / ISO 11452-2 HF radiated 100 V/m pulse resistance ISO 7637-2 / severity level 3 Shock resistance DIN IEC 68-2-27 50 g (11 ms) Vibration resistance DIN IEC 68-2-6 20 g (10...2000 Hz) MTTF [years] Pressure Equipment Directive 555 Sound engineering practice; can be used for group 2 fluids; group 1 fluids on request Mechanical data Weight [g] Materials Materials (wetted parts) 212 stainless steel (1.4404 / 316L); FKM; PA; EPDM/X stainless steel (1.4305 / 303); ceramics; FKM Min. pressure cycles 100 million Process connection threaded connection 1/4" NPT external thread internal thread:M5 Restrictor element integrated no (can be retrofitted) ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PX3244-00 — 13.04.2023 — PX3244 Pressure transmitter with ceramic measuring cell PA-015PRBN14-A-ZVG/US/ /V Remarks Pack quantity 1 pcs. Electrical connection Connector: 1 x M12; coding: A; Contacts: gold-plated Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PX3244-00 — 13.04.2023 —
PX3244 价格&库存
很抱歉,暂时无法提供与“PX3244”相匹配的价格&库存,您可以联系我们找货
