SA4114
SA4114
    IFM(易福门)
    FLOW SENSOR, 4-DIGIT DISPLAY, 4W
SA4114 数据手册
SA4114 Flow sensor SAEXXXXB50KG/US-100 L 1 I, II 2 3 4 100 mm LEDs Display unit not used alphanumeric display 4-digit red/green programming buttons upper part of the housing can be rotated 345° Product characteristics Number of inputs and outputs Number of analogue outputs: 2 Process connection diameter Ø 8 mm Application Special feature Gold-plated contacts Media water; glycol solutions; air; oils Note on media low-viscosity oils with viscosity: ≤ 40 mm²/s (104 °F) high-viscosity oils with viscosity: > 40 mm²/s (104 °F) Medium temperature Pressure rating [°F] -4...212 [bar] 50 Electrical data Operating voltage [V] 18...30 DC ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SA4114-00 — 13.04.2023 — SA4114 Flow sensor SAEXXXXB50KG/US-100 Current consumption [mA] Protection class III Reverse polarity protection Power-on delay time < 100 yes [s] 10 Inputs / outputs Number of inputs and outputs Number of analogue outputs: 2 Outputs Total number of outputs 2 Output signal analogue signal Number of analogue outputs Analogue current output Max. load 2 [mA] [Ω] Short-circuit protection 4...20; (scalable) 350 yes Type of short-circuit protection pulsed Overload protection yes Measuring/setting range Probe length L [mm] Operating mode 100 relative; absolutely liquid; absolutely gaseous; (absolute: reference measurement recommended; Factory setting: relative) Liquids Resolution [ft/s] 0.05 Analogue start point ASP [ft/s] 0...7.95 Analogue end point AEP [ft/s] 1.9...9.85 Resolution [ft/s] 2 Analogue start point ASP [ft/s] 0...264 Analogue end point AEP [ft/s] 64...328 Measuring range [°F] -4...212 Resolution [°F] 0.5 Analogue start point [°F] -4...169 Analogue end point [°F] 39...212 In steps of [°F] 0.5 Gases Temperature monitoring Liquid media - absolute operating mode Setting range [ft/s] 0...9.85 Greatest sensitivity [ft/s] 0.15...9.85 Liquid media - relative operating mode Setting range [ft/s] 0...19.5 Greatest sensitivity [ft/s] 0.15...9.85 Gases - operating mode "absolute" Setting range [ft/s] 0...328 Greatest sensitivity [ft/s] 6...328 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SA4114-00 — 13.04.2023 — SA4114 Flow sensor SAEXXXXB50KG/US-100 Gases - operating mode "relative" Setting range [ft/s] 0...656 Greatest sensitivity [ft/s] 6...328 Accuracy / deviations Temperature drift [cm/s x 1/K] Temperature gradient 0,01 fps x 1/K (< 68 °F; > 158 °F) [K/min] 100 Absolute operating mode Repeatability 0,05 m/s; (water; flow velocity: 0,05...3 m/s) Relative operating mode Accuracy ± (7 % MW + 2 % MEW); (for relative mode in the range of maximum sensitivity under the following conditions:; water: 68...158 °F; inlet length: 5 ft; DN25 (DIN 2448); mounting position according to instructions; Accuracy can differ for other media and mounting positions.) Repeatability 0,05 m/s; (water; flow velocity: 0,05...3 m/s) Temperature monitoring Temperature drift ± 0,003 K/°F Accuracy [K] ± 0,3 / ± 1; (water; flow velocity: 1...9,85 fps / air; flow velocity: > 32,8 fps) [s] 0.5; (T09; water; glycol: 0,8 s; air: 7 s; oil: 1,8 s; each T09) [s] 1,5 (T09); (water; flow velocity: 1...9,85 fps) Response times Response time Temperature monitoring Dynamic response T05 / T09 Software / programming Parameter setting options medium selection; Damping; Teach function; display can be rotated and switched off; standard unit of measurement; process value colour Operating conditions Ambient temperature [°F] -40...176 Storage temperature [°F] -40...212 Protection IP 65; IP 67 Tests / approvals EMC DIN EN 60947-5-9 Shock resistance DIN EN 60068-2-27 50 g (11 ms) Vibration resistance DIN EN 60068-2-6 5 g (10...2000 Hz) MTTF [years] UL approval 179 UL Approval no. I018 File number UL E174189 Mechanical data Weight [g] 262 Materials stainless steel (1.4404 / 316L); PBT-GF20; PBT-GF30 Materials (wetted parts) stainless steel (1.4404 / 316L) Process connection diameter Ø 8 mm Displays / operating elements Display Display unit 6 x LED, green (%, fps, gpm, cfm, °F, 10³) measured values alphanumeric display, red/green 4-digit ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SA4114-00 — 13.04.2023 — SA4114 Flow sensor SAEXXXXB50KG/US-100 Remarks Remarks MW = measured value MEW = Final value of the measuring range Pack quantity 1 pcs. Electrical connection Connector: 1 x M12; coding: A; Contacts: gold-plated Connection OUT1: OUT2: BK = BN = BU = WH = colours to DIN EN 60947-5-2 analogue output Temperature monitoring analogue output volumetric flow quantity monitoring Core colours : black brown blue white ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SA4114-00 — 13.04.2023 —
SA4114
物料型号:型号为LM358P
器件简介:LM358P是一款双运算放大器集成电路,采用8引脚DIP封装。它具有低功耗、低输入偏置电流等特点,适用于音频放大、信号处理等多个领域。
引脚分配:LM358P共有8个引脚,其中1脚为反相输入端,2脚为非反相输入端,3脚为输出端,4脚为V+供电,5脚为负供电V-,6脚为反相输入端(第二个放大器),7脚为非反相输入端(第二个放大器),8脚为输出端(第二个放大器)。
参数特性:LM358P的工作电压范围为3-32V,单位增益带宽为1MHz,输入偏置电流小于100nA,增益带宽积为1MHz。
功能详解:LM358P包含两个独立的运算放大器,可以用于非反相放大、反相放大、差分放大等多种应用。具体应用时需要根据电路设计选择合适的电阻、电容等元件。
应用信息:LM358P适用于音频放大、信号处理、传感器信号放大等多种模拟信号处理场合。
SA4114 价格&库存
很抱歉,暂时无法提供与“SA4114”相匹配的价格&库存,您可以联系我们找货
SA4114
    • 1+4071.665211+529.30330
