SD6601
SD6601
    IFM(易福门)
    Gas PMIC - 栅极驱动器 0.15 ~ 44.15 scfm 公型 - 1/2"(12.7mm)NPT 不锈钢
SD6601 数据手册
SD6601 Industrial gas counter SDN12DGXFRKG/US-100 Product characteristics Number of inputs and outputs Number of digital outputs: 2; Number of analogue outputs: 1 Process connection threaded connection 1/2" NPT DN15 Pressure monitoring Measuring range [psi] -15...232 Application Application for industrial applications Media Argon (Ar); carbon dioxide (CO2); nitrogen (N2); compressed air Medium temperature [°F] 14...140 Min. bursting pressure [psi] 928 Pressure rating [psi] 232 MAWP (for applications according to CRN) [bar] 9.7 Electrical data Operating voltage Current consumption [V] [mA] 18...30 DC; (to SELV/PELV) < 80 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SD6601-00 — 13.04.2023 — SD6601 Industrial gas counter SDN12DGXFRKG/US-100 Protection class III Reverse polarity protection Power-on delay time yes [s] 1 Inputs / outputs Number of inputs and outputs Number of digital outputs: 2; Number of analogue outputs: 1 Inputs Inputs counter reset Outputs Output signal switching signal; analogue signal; pulse signal; IO-Link; (configurable) Electrical design PNP/NPN Number of digital outputs 2 Output function normally open / normally closed; (parameterisable) Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] Number of analogue outputs Analogue current output Max. load 2.5 150; (per output) 1 [mA] [Ω] Pulse output 4...20; (scalable) 500 consumed quantity meter Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Measuring/setting range Measuring range [scfh] 8...2648 Measuring range [scfm] 0.15...44.15 Measuring range [ft/s] 1...327.4 Display range [scfh] 0...3178 Display range [scfm] 0...52.95 Display range [ft/s] 0...393 Resolution [scfh] 2 Resolution [scfm] 0.05 Resolution [ft/s] 0.2 Set point SP [scfh] 23...2648 Set point SP [scfm] 0.38...44.13 Set point SP [ft/s] 2.8...327.3 Reset point rP [scfh] 10...2635 Reset point rP [scfm] 0.16...43.91 Reset point rP [ft/s] 1.2...325.7 Analogue start point ASP [scfh] 0...2119 Analogue start point ASP [scfm] 0...35.31 Analogue start point ASP [ft/s] 0...261.9 Analogue end point AEP [scfh] 530...2649 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SD6601-00 — 13.04.2023 — SD6601 Industrial gas counter SDN12DGXFRKG/US-100 Analogue end point AEP [scfm] 8.83...44.14 Analogue end point AEP [ft/s] 65.5...327.4 Low flow cut-off LFC [scfh] 3...28 Low flow cut-off LFC [scfm] 0.05...0.47 Low flow cut-off LFC [ft/s] 0.4...3.5 In steps of [scfh] 1 In steps of [scfm] 0.01 In steps of [ft/s] 0.1 Measuring range [psi] -15...232 Display range [psi] -15...290 Resolution [psi] 1 Set point SP [psi] -13...232 Reset point rP [psi] -15...231 Analogue start point [psi] -15...186 Analogue end point [psi] 32...232 In steps of [psi] 1 Pressure monitoring Volumetric flow quantity monitoring Measuring range 0...100000000 m³ 0...353146667.2 scf Display range 0...100000000 m³ 0...353146667.2 scf Set point SP 0.001...10000000 m³ 0.05...353146667.2 scf Pulse value 0.001...10000000 m³ 0.05...353146667.2 scf 0.0001 m³ 0.005 scf In steps of Pulse length [s] 0.002...2 Temperature monitoring Measuring range -10...60 °C 14...140 °F Display range -24...74 °C -11.2...165.2 °F Resolution 0.2 °C 0.5 °F Set point SP -9.7...60 °C 14.6...140 °F Reset point rP -10...59.7 °C 14...139.4 °F Analogue start point -10...46 °C 14...114.8 °F Analogue end point 4...60 °C 39.2...140 °F In steps of 0.1 °C 0.1 °F Accuracy / deviations Temperature coefficient [1/K] Accuracy (in the measuring range) Repeatability ± 0,07 % MW ± (6 % MW + 0,6 % MEW) ± (0,4 % MW + 0,1 % MEW) Pressure monitoring Repeatability [% of the final value] ± 0,2 Characteristics deviation [% of the final value] < ± 0,5; (BFSL = Best Fit Straight Line) Greatest TEMPCO of the span [% MEW / 10 K] ± 0,3 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SD6601-00 — 13.04.2023 — SD6601 Industrial gas counter SDN12DGXFRKG/US-100 Greatest TEMPCO of the zero point [% MEW / 10 K] ± 0,1 Temperature monitoring Accuracy [K] ± 0,5; (medium flow in the limit area of the flow measurement range) Response time [s] 0.1; (dAP = 0) Damping process value dAP [s] 0...5 [s] 0.05 [s] T09 = 0,5 Response times Pressure monitoring Response time Temperature monitoring Dynamic response T05 / T09 Software / programming Parameter setting options hysteresis / window; normally open / normally closed; current/pulse output; display can be rotated and switched off; Display unit; totaliser Interfaces Communication interface IO-Link Transmission type COM2 (38,4 kBaud) IO-Link revision 1.1 SDCI standard IEC 61131-9 CDV Profiles Digital Measuring Sensor (0x800A), Identification and Diagnosis (0x4000) SIO mode yes Required master port type A Process data analogue 8 Process data binary 2 Min. process cycle time [ms] Supported DeviceIDs 7.2 Type of operation DeviceID Default 865 Operating conditions Ambient temperature [°F] 32...140 Storage temperature [°F] -4...185 Max. relative air humidity [%] 90 Protection IP 65; IP 67 Tests / approvals EMC DIN EN 60947-5-9 Vibration resistance DIN EN 68000-2-6 MTTF [years] UL approval Pressure Equipment Directive 5 g (10...2000 Hz) 183 UL Approval no. I012 File number UL E174189 Sound engineering practice; can be used for stable gases fluid group 2 Mechanical data Weight [g] Materials 742.5 PBT+PC-GF30; PPS GF40; stainless steel (1.4301 / 304); stainless steel (1.4305 / 303); steel (1.5523) galvanised; 2.0401 (brass / CW614N); FKM ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SD6601-00 — 13.04.2023 — SD6601 Industrial gas counter SDN12DGXFRKG/US-100 Materials (wetted parts) stainless steel (1.4301 / 304); stainless steel (1.4305 / 303); FKM; ceramics glass passivated; PPS GF40; Al2O3 (ceramics); acrylate Process connection threaded connection 1/2" NPT DN15 Displays / operating elements Display colour display 1,44", 128 x 128 pixels 2 x LED, yellow Remarks Remarks MW = measured value MEW = Final value of the measuring range Standard conditions: 1013.25 mbar / 15 °C / 0 % relative humidity For information about installation and operation please see the operating instructions. Pack quantity 1 pcs. Electrical connection Connector: 1 x M12; coding: A Connection OUT1/IO-Link: OUT2/InD: switching output flow switching output temperature switching output pressure Pulse output quantity meter signal output Preset counter switching output flow switching output temperature switching output pressure analogue output flow analogue output temperature analogue output pressure signal output Preset counter Pulse output quantity meter input counter reset ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SD6601-00 — 13.04.2023 —
SD6601 价格&库存
很抱歉,暂时无法提供与“SD6601”相匹配的价格&库存,您可以联系我们找货
