SM8604
SM8604
    IFM(易福门)
    MAGNETIC-INDUCTIVE FLOW METER, 4
SM8604 数据手册
SM8604 Magnetic-inductive flow meter SMN11GGX50KG/US-100 Product characteristics Number of inputs and outputs Number of analogue outputs: 2 Measuring range 0.2...100 l/min Process connection 0.1...26.4 gpm threaded connection 1" NPT DN25 Application Special feature Gold-plated contacts Application for industrial applications Media conductive liquids; water; hydrous media Note on media conductivity: ≥ 20 µS/cm viscosity: < 70 mm²/s (40 °C) Medium temperature [°C] -10...70 Pressure rating [bar] 16 Pressure rating [Mpa] 1.6 MAWP (for applications according to CRN) [bar] 11.2 Electrical data Operating voltage Current consumption [V] [mA] Protection class 120; (24 V) III Reverse polarity protection Power-on delay time 20...30 DC; (to SELV/PELV) yes [s] 5 Inputs / outputs Number of inputs and outputs Number of analogue outputs: 2 Outputs Total number of outputs Output signal 2 analogue signal ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SM8604-00 — 13.04.2023 — SM8604 Magnetic-inductive flow meter SMN11GGX50KG/US-100 Number of analogue outputs Analogue current output Max. load 2 [mA] 4...20; (scalable) [Ω] 500 Overload protection yes Measuring/setting range Measuring range 0.2...100 l/min 0.1...26.4 gpm Display range -120...120 l/min -31.7...31.7 gpm Resolution 0.1 l/min 0.05 gpm Analogue start point ASP 0...80 l/min 0...21.1 gpm Analogue end point AEP 20...100 l/min 5.3...26.4 gpm In steps of 0.1 l/min 0.05 gpm Temperature monitoring Measuring range [°C] -20...80 Resolution [°C] 0.2 Analogue start point [°C] -20...60 Analogue end point [°C] 0...80 In steps of [°C] 0.2 Accuracy / deviations Flow monitoring Accuracy (in the measuring range) ± (2 % MW + 0,5 % MEW) Repeatability ± 0,2% MEW Temperature monitoring Accuracy [K] ± 2,5 (Q > 1 l/min) Response time [s] 0.15; (dAP = 0, T19) Damping process value dAP [s] 0...3 [s] T09 = 20 (Q > 1 l/min) Response times Flow monitoring Temperature monitoring Dynamic response T05 / T09 Operating conditions Ambient temperature [°C] -10...60 Storage temperature [°C] -25...80 Protection IP 67 Tests / approvals EMC DIN EN 60947-5-9 500 withstand voltage (V DC) CPA approval model number 009MI accuracy class - maximum allowable error ± 2,5 % FS Q (min) 0,01 m³/h Q (t) - Q (max) 6 m³/h DIN EN 60068-2-27 20 g (11 ms) Shock resistance Vibration resistance MTTF DIN EN 60068-2-6 [years] 5 g (10...2000 Hz) 175 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SM8604-00 — 13.04.2023 — SM8604 Magnetic-inductive flow meter SMN11GGX50KG/US-100 Pressure Equipment Directive Sound engineering practice; can be used for group 2 fluids; group 1 fluids on request Mechanical data Weight [g] 636.2 Materials stainless steel (1.4404 / 316L); PBT-GF20; PC; FKM; TPE Materials (wetted parts) stainless steel (1.4404 / 316L); PEEK; FKM Process connection threaded connection 1" NPT DN25 Displays / operating elements Display Display unit 6 x LED, green (l/min, m³/h, gpm, gph, °C, °F) measured values alphanumeric display, 4-digit programming alphanumeric display, 4-digit Display unit l/min; m³/h; gpm; gph; °C; °F Remarks Remarks MW = measured value MEW = Final value of the measuring range Pack quantity 1 pcs. Electrical connection Connector: 1 x M12; coding: A; Contacts: gold-plated Connection OUT1: OUT2: BK = BN = BU = WH = colours to DIN EN 60947-5-2 analogue output Temperature monitoring analogue output volumetric flow quantity monitoring Core colours : black brown blue white ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SM8604-00 — 13.04.2023 — SM8604 Magnetic-inductive flow meter SMN11GGX50KG/US-100 Diagrams and graphs Pressure loss dP Pressure loss Q volumetric flow quantity ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SM8604-00 — 13.04.2023 —
SM8604 价格&库存
很抱歉,暂时无法提供与“SM8604”相匹配的价格&库存,您可以联系我们找货
