SM9001
SM9001
    IFM(易福门)
    MAGNETIC-INDUCTIVE FLOW METER, 4
SM9001 数据手册
SM9001 Magnetic-inductive flow meter SMR21XGXFRKG/US Product characteristics Number of inputs and outputs Measuring range Process connection Number of digital outputs: 2; Number of analogue outputs: 1 80...4800 gph 1.3...80 gpm threaded connection G 2 DN50 flat seal Application Special feature Gold-plated contacts Application totaliser function; empty pipe detection; for industrial applications Installation connection to pipe by means of an adapter Media conductive liquids; water; hydrous media ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SM9001-00 — 27.07.2023 — SM9001 Magnetic-inductive flow meter SMR21XGXFRKG/US Note on media conductivity: ≥ 20 µS/cm viscosity: < 70 mm²/s (40 °C) Medium temperature [°F] 14...176 Pressure rating [bar] 16 MAWP (for applications according to CRN) [bar] 16 Electrical data Operating voltage Current consumption [V] 18...32 DC; (to SELV/PELV) [mA] < 150 Protection class III Reverse polarity protection Power-on delay time yes [s] 5 Inputs / outputs Number of inputs and outputs Number of digital outputs: 2; Number of analogue outputs: 1 Inputs Inputs counter reset Outputs Total number of outputs 2 Output signal switching signal; analogue signal; pulse signal; frequency signal; IO-Link; (configurable) Electrical design PNP/NPN Number of digital outputs 2 Output function normally open / normally closed; (parameterisable) Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] 2 250; (per output) Number of analogue outputs Analogue current output 1 [mA] 4...20; (scalable) Max. load [Ω] 500 Analogue voltage output [V] 0...10; (scalable) Min. load resistance [Ω] 2000 Pulse output flow rate meter Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Frequency of the output [Hz] 0.1...10000 Measuring/setting range Measuring range 80...4800 gph 1.3...80 gpm Display range -5760...5760 gph -96...96 gpm Resolution 5 gph 0.1 gpm Set point SP 105...4800 gph 1.7...80 gpm Reset point rP 80...4775 gph 1.3...79.6 gpm Analogue start point ASP 0...3840 gph 0...64 gpm Analogue end point AEP 960...4800 gph 16...80 gpm Low flow cut-off LFC < 240 gph < 4 gpm ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SM9001-00 — 27.07.2023 — SM9001 Magnetic-inductive flow meter SMR21XGXFRKG/US In steps of 5 gph Measuring dynamics 0.1 gpm 1:60 Volumetric flow quantity monitoring Pulse value 0.02...80 E06 gal In steps of 0.02 gal Pulse length [s] 0,016...2 Measuring range [°F] -4...176 Display range [°F] -40...212 Resolution [°F] 0.5 Set point SP [°F] -2...176 Reset point rP [°F] -3...175 Analogue start point [°F] -4...140 Analogue end point [°F] 32...176 In steps of [°F] 0.5 Temperature monitoring Accuracy / deviations Flow monitoring Accuracy (in the measuring range) ± (0,8 % MW + 0,5 % MEW) Repeatability ± 0,2% MEW Temperature monitoring Temperature drift Accuracy ± 0,0185 °F / K [K] ± 1 (77 °F; Q > 4 gpm) Response time [s] 0.35; (dAP = 0) Delay time programmable dS, dr [s] Damping process value dAP [s] 0...5 [s] T09 = 3 (Q > 4 gpm) Response times Flow monitoring 0...50 Temperature monitoring Dynamic response T05 / T09 Software / programming Parameter setting options Flow monitoring; quantity meter; Preset counter; Temperature monitoring; hysteresis / window; normally open / normally closed; switching logic; current/voltage/frequency/ pulse output; start-up delay; display can be deactivated; Display unit; empty pipe detection Interfaces Communication interface Transmission type IO-Link COM2 (38,4 kBaud) IO-Link revision 1.1 SDCI standard IEC 61131-9 CDV Profiles Smart Sensor: Process Data Variable; Device Identification SIO mode yes Required master port type A Process data analogue 3 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SM9001-00 — 27.07.2023 — SM9001 Magnetic-inductive flow meter SMR21XGXFRKG/US Process data binary 2 Min. process cycle time [ms] Supported DeviceIDs 5 Type of operation DeviceID Default 392 Operating conditions Ambient temperature [°F] 14...140 Storage temperature [°F] -13...176 Protection IP 65; IP 67 Tests / approvals EMC DIN EN 60947-5-9 Shock resistance DIN EN 60068-2-27 20 g (11 ms) Vibration resistance DIN EN 60068-2-6 5 g (10...2000 Hz) MTTF [years] UL approval Pressure Equipment Directive 85 UL Approval no. I008 File number UL E174189 Sound engineering practice; can be used for group 2 fluids; group 1 fluids on request Mechanical data Weight [g] 26 Materials Materials (wetted parts) stainless steel (1.4404 / 316L); stainless steel (1.4571/316Ti ); PEI; FKM; PBT-GF20; TPE-U stainless steel (1.4404 / 316L); stainless steel (1.4571/316Ti ); PEEK; Centellen; FKM Process connection threaded connection G 2 DN50 flat seal Displays / operating elements Display Display unit 6 x LED, green (gpm, gph, gal, °F, 10³, 1000 x 10³) switching status 2 x LED, yellow measured values alphanumeric display, 4-digit programming alphanumeric display, 4-digit Accessories Items supplied sealings: 2, Centellen Label Remarks Remarks MW = measured value MEW = Final value of the measuring range Pack quantity 1 pcs. Electrical connection Connector: 1 x M12; coding: A; Contacts: gold-plated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SM9001-00 — 27.07.2023 — SM9001 Magnetic-inductive flow meter SMR21XGXFRKG/US Connection colours to DIN EN 60947-5-2 switching output empty pipe detection switching output volumetric flow quantity monitoring frequency output volumetric flow quantity monitoring Pulse output quantity meter signal output Preset counter IO-Link switching output empty pipe detection switching output volumetric flow quantity monitoring switching output Temperature monitoring analogue output volumetric flow quantity monitoring analogue output Temperature monitoring input counter reset Core colours : black brown blue white OUT1: OUT2: BK = BN = BU = WH = Diagrams and graphs Pressure loss dP Pressure loss Q volumetric flow quantity ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SM9001-00 — 27.07.2023 —
SM9001 价格&库存
很抱歉,暂时无法提供与“SM9001”相匹配的价格&库存,您可以联系我们找货
