SM6000
SM6000
    IFM(易福门)
    MAGNETIC-INDUCTIVE FLOW METER; P
SM6000 数据手册
SM6000 Magnetic-inductive flow meter SMR12GGXFRKG/US-100 Product characteristics Number of inputs and outputs Number of digital outputs: 2; Number of analogue outputs: 1 Measuring range 0.1...25 l/min Process connection 0.005...1.5 m³/h threaded connection G 1/2 DN15 flat seal Application Special feature Gold-plated contacts Application totaliser function; for industrial applications Installation connection to pipe by means of an adapter Media conductive liquids; water; hydrous media Note on media conductivity: ≥ 20 µS/cm viscosity: < 70 mm²/s (40 °C) Medium temperature [°C] -10...70 Pressure rating [bar] 16 Pressure rating [Mpa] 1.6 MAWP (for applications according to CRN) [bar] 17.7 Electrical data Operating voltage [V] 18...30 DC; (to SELV/PELV) Current consumption [mA] 95; (24 V) Min. insulation resistance [MΩ] 100; (500 V DC) Protection class III Reverse polarity protection Power-on delay time yes [s] 5 Inputs / outputs Number of inputs and outputs Number of digital outputs: 2; Number of analogue outputs: 1 Inputs Inputs counter reset ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SM6000-03 — 13.04.2023 — SM6000 Magnetic-inductive flow meter SMR12GGXFRKG/US-100 Outputs Total number of outputs 2 Output signal switching signal; analogue signal; pulse signal; IO-Link; (configurable) Electrical design PNP/NPN Number of digital outputs 2 Output function normally open / normally closed; (parameterisable) Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] 2 200 Number of analogue outputs Analogue current output Max. load 1 [mA] 4...20; (scalable) [Ω] 500 Analogue voltage output [V] 0...10; (scalable) Min. load resistance [Ω] 2000 Pulse output flow rate meter Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Measuring/setting range Measuring range 0.1...25 l/min 0.005...1.5 m³/h Display range -30...30 l/min -1.8...1.8 m³/h Resolution 0.02 l/min 0.002 m³/h Set point SP 0.25...25 l/min 0.015...1.5 m³/h Reset point rP 0.1...24.9 l/min 0.005...1.495 m³/h Analogue start point ASP 0...20 l/min 0...1.2 m³/h Analogue end point AEP 5...25 l/min 0.3...1.5 m³/h In steps of 0.02 l/min 0.002 m³/h Volumetric flow quantity monitoring Pulse value Pulse length 0.00001...30 000 m³ [s] 0,01...2 Measuring range [°C] -20...80 Resolution [°C] 0.2 Set point SP [°C] -19.2...80 Reset point rP [°C] -19.6...79.6 Analogue start point [°C] -20...60 Analogue end point [°C] 0...80 In steps of [°C] 0.2 Temperature monitoring Accuracy / deviations Flow monitoring Accuracy (in the measuring range) Repeatability ± (0,8 % MW + 0,5 % MEW) ± 0,2% MEW ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SM6000-03 — 13.04.2023 — SM6000 Magnetic-inductive flow meter SMR12GGXFRKG/US-100 Temperature monitoring Accuracy [K] ± 2,5 (Q > 1 l/min) Response time [s] 0.15; (dAP = 0, T19) Delay time programmable dS, dr [s] Damping process value dAP [s] 0...5 [s] T09 = 20 (Q > 1 l/min) Response times Flow monitoring 0...50 Temperature monitoring Dynamic response T05 / T09 Software / programming Parameter setting options Flow monitoring; quantity meter; Preset counter; Temperature monitoring; hysteresis / window; normally open / normally closed; switching logic; current/ voltage/pulse output; start-up delay; display can be deactivated; Display unit Interfaces Communication interface IO-Link Transmission type COM2 (38,4 kBaud) IO-Link revision 1.1 SDCI standard IEC 61131-9 Profiles Smart Sensor: Process Data Variable; Device Identification, Device Diagnosis SIO mode yes Required master port type A Process data analogue 3 Process data binary 2 Min. process cycle time [ms] Supported DeviceIDs 5 Type of operation DeviceID Default 569 Operating conditions Ambient temperature [°C] -10...60 Storage temperature [°C] -25...80 Protection IP 67 Tests / approvals EMC DIN EN 60947-5-9 CPA approval model number 001MI accuracy class - maximum allowable error ± 1,5 % FS Q (min) 0,005 m³/h Q (t) - Q (max) 1,5 m³/h Shock resistance DIN IEC 68-2-27 20 g (11 ms) Vibration resistance DIN IEC 68-2-6 5 g (10...2000 Hz) MTTF [years] Pressure Equipment Directive 162 Sound engineering practice; can be used for group 2 fluids; group 1 fluids on request Mechanical data Weight [g] 544 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SM6000-03 — 13.04.2023 — SM6000 Magnetic-inductive flow meter SMR12GGXFRKG/US-100 Materials stainless steel (1.4404 / 316L); PBT-GF20; PC; FKM; TPE Materials (wetted parts) stainless steel (1.4404 / 316L); PEEK; FKM Process connection threaded connection G 1/2 DN15 flat seal Displays / operating elements Display Display unit 6 x LED, green (l/min, m³/h, l, m³, 10³, °C) switching status 2 x LED, yellow measured values alphanumeric display, 4-digit programming alphanumeric display, 4-digit Remarks Remarks MW = measured value MEW = Final value of the measuring range Pack quantity 1 pcs. Electrical connection Connector: 1 x M12; coding: A; Contacts: gold-plated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SM6000-03 — 13.04.2023 — SM6000 Magnetic-inductive flow meter SMR12GGXFRKG/US-100 Connection colours to DIN EN 60947-5-2 OUT1: OUT2: - switching output volumetric flow quantity monitoring Pulse output quantity meter signal output Preset counter IO-Link switching output volumetric flow quantity monitoring switching output Temperature monitoring analogue output volumetric flow quantity monitoring analogue output Temperature monitoring input counter reset Core colours : black brown blue white BK = BN = BU = WH = Diagrams and graphs Pressure loss dP Pressure loss Q volumetric flow quantity ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SM6000-03 — 13.04.2023 —
SM6000 价格&库存
很抱歉,暂时无法提供与“SM6000”相匹配的价格&库存,您可以联系我们找货
SM6000
    • 1+6475.13911
    库存:1
