SM6020
SM6020
    IFM(易福门)
    MAGNETIC-INDUCTIVE FLOW METER,9.
SM6020 数据手册
SM6020 Magnetic-inductive flow meter SMR12XGXFRKG/US-100 Product characteristics Number of inputs and outputs Number of digital outputs: 2; Number of analogue outputs: 1 Process connection G 1/2 DN15 flat seal Application Special feature Gold-plated contacts Media conductive liquids; water; hydrous media Note on media conductivity: ≥ 20 µS/cm viscosity: < 70 mm²/s (40 °C) Medium temperature [°C] -20...90 Pressure rating [bar] 16 Pressure rating [Mpa] 1.6 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SM6020-00 — 13.04.2023 — SM6020 Magnetic-inductive flow meter SMR12XGXFRKG/US-100 Electrical data Operating voltage Current consumption [V] 18...30 DC; (to SELV/PELV) [mA] < 80 Protection class III Reverse polarity protection Power-on delay time yes [s] 5 Inputs / outputs Number of inputs and outputs Number of digital outputs: 2; Number of analogue outputs: 1 Inputs Inputs counter reset Outputs Total number of outputs 2 Output signal switching signal; analogue signal; pulse signal; IO-Link; frequency signal; (configurable) Electrical design PNP/NPN Number of digital outputs 2 Output function normally open / normally closed; (parameterisable) Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] 2 100 Number of analogue outputs Analogue current output Max. load 1 [mA] 4...20; (scalable) [Ω] 500 Pulse output flow rate meter Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Measuring/setting range Measuring range 0.05...35 l/min 0.003...2.1 m³/h 0.6...555 gph 0.01...9.25 gpm Display range -42...42 l/min -2.5...2.5 m³/h -666...666 gph -11.1...11.1 gpm Resolution 0.02 l/min 0.002 m³/h 0.6 gph 0.01 gpm Set point SP 0.25...35 l/min 0.015...2.1 m³/h 4.2...555 gph 0.07...9.25 gpm Reset point rP 0...34.8 l/min 0...2.08 m³/h 1.2...552 gph 0.02...9.2 gpm Analogue start point ASP 0...28 l/min 0...1.7 m³/h 0...666 gph 0...7.4 gpm Analogue end point AEP 7...35 l/min 0.42...2.1 m³/h 111...555 gph 1.85...9.25 gpm Low flow cut-off LFC 0.05...1.75 l/min 0.003...0.1 m³/h 0.6...27.6 gph 0.01...0.46 gpm Frequency end point, FEP 7...35 l/min 0.42...2.1 m³/h 111.6...555 gph 1.86...9.25 gpm Frequency at the end point FRP [Hz] 1...10000 Volumetric flow quantity monitoring Pulse length [s] Pulse value 0.001...2 0.001...99990000 I Temperature monitoring Measuring range [°C] -20...90 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SM6020-00 — 13.04.2023 — SM6020 Magnetic-inductive flow meter SMR12XGXFRKG/US-100 Display range [°C] -42...112 Resolution [°C] 0.1 Set point SP [°C] -19.6...90 Reset point rP [°C] -20...89.6 Analogue start point [°C] -20...68 Analogue end point [°C] 2...90 In steps of [°C] 0.1 Accuracy / deviations Flow monitoring Accuracy (in the measuring range) ± (0,8 % MW + 0,2 % MEW) Repeatability ± 0,2 % MEW Temperature monitoring Accuracy [K] ± 2,5 (Q > 5 % MEW) Start-up delay [s] 0...50 Response time [s] < 0.25; (dAP = 0, T09) Damping process value dAP [s] 0...5 [s] 15; (Q > 10 % MEW, T09) Response times Flow monitoring Temperature monitoring Response time Software / programming Parameter setting options hysteresis / window; normally open / normally closed; switching logic; frequency output; current/pulse output; start-up delay; display can be deactivated; Display unit Interfaces Communication interface IO-Link Transmission type COM2 (38,4 kBaud) IO-Link revision 1.1 SDCI standard IEC 61131-9 Profiles Smart Sensor: Process Data Variable; Device Identification, Device Diagnosis SIO mode yes Required master port type A Process data analogue 3 Process data binary 2 Min. process cycle time [ms] Supported DeviceIDs 6 Type of operation DeviceID Default 949 Operating conditions Ambient temperature [°C] -20...60 Storage temperature [°C] -25...80 Protection IP 65; IP 67 Tests / approvals EMC DIN EN 60947-5-9 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SM6020-00 — 13.04.2023 — SM6020 Magnetic-inductive flow meter SMR12XGXFRKG/US-100 CPA approval model number 005MI accuracy class - maximum allowable error ± 1,0 % FS Q (min) 0,003 m³/h Q (t) - Q (max) 2,1 m³/h Shock resistance DIN IEC 68-2-27 20 g (11 ms) Vibration resistance DIN IEC 68-2-6: 5 g (10...2000 Hz) MTTF [years] UL approval Pressure Equipment Directive 114 UL Approval no. I014 File number UL E174189 Sound engineering practice; can be used for group 2 fluids; group 1 fluids on request Mechanical data Weight [g] Materials Materials (wetted parts) 717.2 stainless steel (1.4408/316); stainless steel (1.4404 / 316L); PC; PBT+PC-GF30 stainless steel (1.4404 / 316L); PEEK; carbon fibre PEEK; FKM; Centellen Process connection G 1/2 DN15 flat seal Displays / operating elements Display colour display 1,44", 128 x 128 pixels 2 x LED, yellow Remarks Remarks MW = measured value MEW = Final value of the measuring range Pack quantity 1 pcs. Electrical connection Connector: 1 x M12; coding: A; Contacts: gold-plated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SM6020-00 — 13.04.2023 — SM6020 Magnetic-inductive flow meter SMR12XGXFRKG/US-100 Connection OUT1: OUT2: BK = BN = BU = WH = switching output volumetric flow quantity monitoring switching output Temperature monitoring Pulse output quantity meter frequency output volumetric flow monitoring frequency output Temperature monitoring signal output Preset counter IO-Link switching output volumetric flow quantity monitoring switching output Temperature monitoring analogue output flow analogue output temperature input counter reset colours to DIN EN 60947-5-2 Core colours : black brown blue white ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SM6020-00 — 13.04.2023 — SM6020 Magnetic-inductive flow meter SMR12XGXFRKG/US-100 Diagrams and graphs Pressure loss / volumetric flow quantity ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SM6020-00 — 13.04.2023 —
SM6020 价格&库存
很抱歉,暂时无法提供与“SM6020”相匹配的价格&库存,您可以联系我们找货
