TD2263
TD2263
    IFM(易福门)
    模块
    TEMPERATURE TRANSMITTER, 6MM DIA
TD2263 数据手册
TD2263 Temperature transmitter with display TD-250FFED06-A-ZVG/US EL = installation length Product characteristics Number of inputs and outputs Number of analogue outputs: 1 Measuring range -50...150 °C Process connection Installation length EL -58...302 °F diameter Ø 6 mm [mm] 250 Application Measuring element 1 x Pt 1000; (to DIN EN 60751, class A) Media liquids and gases Pressure rating Vacuum resistance [bar] [mbar] 160 -1000 Electrical data Operating voltage Current consumption [V] [mA] Protection class < 50 III Reverse polarity protection Power-on delay time 18...32 DC; ("supply class 2" to cULus) yes [s] 2 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — TD2263-00 — 16.06.2023 — TD2263 Temperature transmitter with display TD-250FFED06-A-ZVG/US Inputs / outputs Number of inputs and outputs Number of analogue outputs: 1 Outputs Total number of outputs 1 Output signal analogue signal; IO-Link; (configurable) Number of analogue outputs Analogue current output Max. load 1 [mA] 4...20 [Ω] 300 Short-circuit protection yes Overload protection yes Measuring/setting range Measuring range -50...150 °C -58...302 °F Factory setting 0...300 °F Resolution Resolution of analogue output [K] Resolution of display [K] 0.28 [K] ± 0,3 + (± 0,1 % MS) 0.04 Accuracy / deviations Precision analogue output Temperature coefficient [% of the span / 10 K] 0,1; (in case of deviation from the reference condition 25 °C) Response times Dynamic response T05 / T09 [s] 1/3 Interfaces Communication interface IO-Link Transmission type COM2 (38,4 kBaud) IO-Link revision 1.1 Operating conditions Ambient temperature [°C] -25...80 Storage temperature [°C] -40...100 Protection IP 67; IP 68; IP 69K Tests / approvals EMC DIN EN 61000-6-2 DIN EN 61000-6-3 Shock resistance DIN IEC 68-2-27 Vibration resistance MTTF DIN IEC 68-2-6 [years] Note on approval 50 g (11 ms) 10 g (10...2000 Hz) 407 factory certificate available as download at www.factory-certificate.ifm UL approval UL Approval no. K001 Mechanical data Weight Dimensions Materials Materials (wetted parts) [g] 252 [mm] Ø6 stainless steel (1.4404 / 316L); PEI; FKM stainless steel (1.4404 / 316L) electropolished ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — TD2263-00 — 16.06.2023 — TD2263 Temperature transmitter with display TD-250FFED06-A-ZVG/US Process connection diameter Ø 6 mm Surface characteristics Ra/Rz of the wetted parts Ra: < 0.8 Probe diameter [mm] 6 Installation length EL [mm] 250 Displays / operating elements Display 7-segment LED display, 4-digit display unit / status, °C / °F Remarks Remarks MS = set measuring span The values for accuracy apply to flowing water. Pack quantity 1 pcs. Electrical connection Connector: 1 x M12; coding: A Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — TD2263-00 — 16.06.2023 —
TD2263 价格&库存
很抱歉,暂时无法提供与“TD2263”相匹配的价格&库存,您可以联系我们找货
