VSA001
VSA001
    IFM(易福门)
    圆柱形,有螺纹
    加速 传感器 模拟 面板安装 连接器
VSA001 数据手册
VSA001 Acceleration sensor VIBRATION SENSOR 1 conical angle = 90° Product characteristics Measuring range of vibration Frequency range [g] -25...25 [Hz] 1...6000 Measuring principle capacitive Application Design for connection to external diagnostic electronics VSE Application vibration detection Electrical data Operating voltage [V] 7.2...10.8 DC Current consumption [mA] < 15 Min. insulation resistance [MΩ] 100; (500 V DC) Protection class III Reverse polarity protection yes Sensor type microelectromechanical system (MEMS) Outputs Analogue current output Max. load [mA] 0...10 [Ω] 300 [g] -25...25 [Hz] 1...6000 Measuring/setting range Measuring range of vibration Frequency range Measuring principle Sensitivity capacitive [µA/g] Number of measurement axes 142 1 Accuracy / deviations Linearity deviation 0,2 % Operating conditions Ambient temperature [°C] Note on ambient temperature Storage temperature Protection -30...125 cULus: < 85 °C [°C] -30...125 IP 67; IP 68; IP 69K ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — VSA001-03 — 13.04.2023 — VSA001 Acceleration sensor VIBRATION SENSOR Tests / approvals EMC EN 61000-6-2 EN 61000-6-3 Shock resistance DIN EN 60068-2-27 Vibration resistance DIN EN 60068-2-6 50 g 11 ms 500 g 1 ms MTTF [years] 20 g / 10 ... 2000 Hz 1701 Mechanical data Weight [g] Type of mounting 50 M8 x 1,25 Materials housing: stainless steel (1.4404 / 316L) Tightening torque [Nm] Mechanische Überlastfestigkeit [g] 8 500 Accessories Items supplied washer, conical Remarks Pack quantity 1 pcs. Electrical connection Connector: 1 x M12; coding: A; Maximum cable length: 250 m 1 2 3 4 L+ (+9 V) I out GND Test ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — VSA001-03 — 13.04.2023 —
VSA001 价格&库存
很抱歉,暂时无法提供与“VSA001”相匹配的价格&库存,您可以联系我们找货
