VSA005
VSA005
    IFM(易福门)
    模块
    加速 传感器 模拟 底座安装 电缆/引线
VSA005 数据手册
VSA005 Acceleration sensor VIBRATION SENSOR Product characteristics Measuring range of vibration Frequency range [g] [Hz] Measuring principle -25...25 1...10000 capacitive Application Special feature Screened cable; Drag chain suitability Design for connection to external diagnostic electronics VSE Application vibration detection Electrical data Operating voltage [V] 7.2...10.8 DC Current consumption [mA] < 15 Min. insulation resistance [MΩ] 100; (500 V DC) Protection class III Reverse polarity protection yes Sensor type microelectromechanical system (MEMS) Outputs Analogue current output Max. load [mA] 0...10 [Ω] 300 [g] -25...25 Measuring/setting range Measuring range of vibration Frequency range [Hz] Measuring principle Sensitivity Number of measurement axes 1...10000 capacitive [µA/g] 142 1 Accuracy / deviations Linearity deviation 0,2 % ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — VSA005-02 — 13.04.2023 — VSA005 Acceleration sensor VIBRATION SENSOR Operating conditions Ambient temperature [°C] -20...80 Note on ambient temperature cULus: < 80 °C Storage temperature [°C] -20...80 Max. relative air humidity [%] 80; (40 °C: 50 % non condensing) Protection IP 67 Tests / approvals EMC EN 61000-6-2 EN 61000-6-3 Shock resistance DIN EN 60068-2-27 50 g 11 ms Vibration resistance DIN EN 60068-2-20 20 g / 10 ... 2000 Hz MTTF [years] 2660 [g] 323.5 Mechanical data Weight Type of mounting mounting screw Materials housing: stainless steel (1.4404 / 316L) Tightening torque [Nm] Mechanische Überlastfestigkeit [g] 5 500 Drag chain suitability Drag chain suitability yes bending radius for fixed installation : min. 4 x cable diameter bending radius for flexible use : min. 15 x cable diameter Accessories Items supplied head cap screw: 1 x M5 x 20, Torx 15 Remarks Pack quantity 1 pcs. Electrical connection Cable: 10 m, PUR, Ø 4 mm, shielded; Maximum cable length: 250 m; drain wire connected to the housing; 4 x 0.14 mm² blue black brown white Screen GND test L+ Out drain wire ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — VSA005-02 — 13.04.2023 —
VSA005 价格&库存
很抱歉,暂时无法提供与“VSA005”相匹配的价格&库存,您可以联系我们找货
