VVB001
VVB001
    IFM(易福门)
    圆柱形,有螺纹
    振动 传感器 数字 面板安装 连接器
VVB001 数据手册
VVB001 Vibration sensor VIBRATION IO-LINK SWITCH 1 2 set screw ¼"-28 UNF / M8 set screw ¼"-28 UNF Product characteristics Frequency range [Hz] 2...10000 Measuring principle capacitive v-RMS Measuring range of vibration [mm/s] 0...45 a-Peak / a-RMS Measuring range of vibration 0...50 g 0...490.3 m/s² Application Application industrial machines Electrical data Operating voltage [V] 18...30 DC Current consumption [mA] < 50 Min. insulation resistance [MΩ] 100; (500 V DC) Protection class Reverse polarity protection Sensor type III yes microelectromechanical system (MEMS) Inputs / outputs Number of inputs and outputs Number of digital outputs: 2 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — VVB001-01 — 13.04.2023 — VVB001 Vibration sensor VIBRATION IO-LINK SWITCH Outputs Output signal switching signal; IO-Link Electrical design PNP/NPN; (configurable) Number of digital outputs 2 Output function normally open / normally closed Max. voltage drop switching output DC [V] Max. current load per output [mA] 2 100 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Measuring/setting range Note on setpoint SP Frequency range parameterisable [Hz] 2...10000 Measuring principle capacitive Number of measurement axes 1 v-RMS Measuring range of vibration [mm/s] 0...45 Set point SP [mm/s] 0.2...45 Reset point rP [mm/s] 0...44.8 In steps of [mm/s] 0.2 a-Peak / a-RMS Measuring range of vibration 0...50 g 0...490.3 m/s² Set point SP 0.2...50 g 2...490.3 m/s² Reset point rP 0...49.8 g 0...488.3 m/s² In steps of 0.2 g 2 m/s² Crest Measuring range of vibration 1...50 Set point SP 2...50 Reset point rP 1...49 In steps of 1 Temperature measurement Measuring range [°C] -30...80 Resolution [°C] 0.1 Set point SP [°C] -28...80 Reset point rP [°C] -30...78 In steps of [°C] 2 Accuracy / deviations Accuracy Accuracy Linearity deviation ≤ 4 kHz +/-10 %; ≥ 4...10 kHz: < 3 dB [K] ± 2,5 K + (0,2 x (Umgebungstemperatur - Oberflächentemperatur)) 2% ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — VVB001-01 — 13.04.2023 — VVB001 Vibration sensor VIBRATION IO-LINK SWITCH Software / programming Parameter setting options Software Diagnostic functions self-test Interfaces Communication interface IO-Link Transmission type COM2 (38,4 kBaud); COM3 (230,4 kBaud) IO-Link revision 1.1 SDCI standard IEC 61131-9: 2013-07 Profiles Blob (0x0030); Measuring sensor (0x800A); Common Profile (0x4000) SIO mode yes Required master port type A Process data analogue 10 Process data binary Min. process cycle time 2 [ms] 3.6 IO-Link functions (acyclical) filter for v-RMS, a-RMS, a-Peak; Hysteresis; window; switch points; switching logic Supported DeviceIDs Type of operation DeviceID Status A (COM2) 1028 Status B (COM2 / COM3) 1367 Note For further information please see the IODD PDF file under "Downloads" Operating conditions Ambient temperature [°C] -30...80 Storage temperature [°C] -30...80 Protection IP 67; IP 68; IP 69K Tests / approvals EMC 2014/30/EU DIN EN 61000-6-2 DIN EN 61000-6-3 Shock resistance DIN EN 60068-2-27 Vibration resistance DIN EN 60068-2-6 50 g 11 ms 500 g 1 ms MTTF [years] UL approval 20 g / 10...3000 Hz 299 Ta -30...70 °C UL Approval no. L002 Mechanical data Weight [g] Type of mounting set screw Materials Tightening torque 116 housing: stainless steel (1.4404 / 316L) [Nm] 8 Accessories Items supplied set screw: 1 x 1/4" 28 UNF / M8 set screw: 1 x 1/4"28 UNF x 5/8" DIN916 Remarks Pack quantity 1 pcs. ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — VVB001-01 — 13.04.2023 — VVB001 Vibration sensor VIBRATION IO-LINK SWITCH Electrical connection Connector: 1 x M12; coding: A; Maximum cable length: 20 m 1 2 3 4 L+ OUT2 LOUT1 switching output or IO-Link ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — VVB001-01 — 13.04.2023 —
VVB001 价格&库存
很抱歉,暂时无法提供与“VVB001”相匹配的价格&库存,您可以联系我们找货
