KG3500
KG3500
    IFM(易福门)
    圆柱形,有螺纹-M18
    CAPACITIVE PROXIMITY SENSOR, 18M
KG3500 数据手册
KG3500 Capacitive sensor KGE2008-FBOA/LS100AK Product characteristics Output function Sensing range normally open / closed; (selectable) [mm] Housing Dimensions 8 Threaded type [mm] M18 x 1 Electrical data Operating voltage [V] 20...250 AC/DC Protection class II Reverse polarity protection no Outputs Output function normally open / closed; (selectable) Max. voltage drop switching output DC [V] Max. voltage drop switching output AC [V] 6 6 Minimum load current [mA] 4 Max. leakage current [mA] 2.0 (250 V AC) / 1.5 (110 V AC) / 0.8 (24 V DC) Permanent current rating of switching output AC [mA] Permanent current rating of switching output DC [mA] Short-time current rating of switching output [mA] Switching frequency AC [Hz] 25 Switching frequency DC [Hz] 50 250; (350 (...50 °C)) 100 2100; (50 ms / 1 Hz) Short-circuit proof no Overload protection no ifm efector, inc. • 1100 Atwater Drive • Malvern • PA 19355 — We reserve the right to make technical alterations without prior notice. — EN-US — KG3500-00 — 06.03.2003 — KG3500 Capacitive sensor KGE2008-FBOA/LS100AK Monitoring range Sensing range [mm] 8 Real sensing range Sr [mm] 8 ± 10 % Operating distance [mm] 0...6.5 Accuracy / deviations Correction factor glass: 0.4 / water: 1 / ceramics: 0.2 / PVC: 0.2 Hysteresis [% of Sr] 1...15 Switch-point drift [% of Sr] -15...15 [°C] -25...80 Operating conditions Ambient temperature Protection IP 65 Tests / approvals EMC EN 60947-5-2 Mechanical data Weight [g] 72.575 Housing Threaded type Mounting non-flush mountable Dimensions [mm] M18 x 1 Thread designation M18 x 1 Material PBT; end cap: PC Displays / operating elements Display Switching status 1 x LED, yellow Accessories Items supplied lock nuts: 2 screwdriver: 1 Remarks Pack quantity 1 pcs. ifm efector, inc. • 1100 Atwater Drive • Malvern • PA 19355 — We reserve the right to make technical alterations without prior notice. — EN-US — KG3500-00 — 06.03.2003 — KG3500 Capacitive sensor KGE2008-FBOA/LS100AK Electrical connection - plug Connector: 1 x 1/2"; coding: C ifm efector, inc. • 1100 Atwater Drive • Malvern • PA 19355 — We reserve the right to make technical alterations without prior notice. — EN-US — KG3500-00 — 06.03.2003 —
KG3500 价格&库存
很抱歉,暂时无法提供与“KG3500”相匹配的价格&库存,您可以联系我们找货
