SBN234
SBN234
    IFM(易福门)
    FLOW METER, 4 DIGIT DISPLAY, 4WI
SBN234 数据手册
SBN234 Flow meter with fast response and display SBN34IQ0FRKG Please note the changed housing design! Product characteristics Number of inputs and outputs Number of digital outputs: 2; Number of analog outputs: 1 Measuring range 10...600 gph Process connection 0.2...10 gpm threaded connection 3/4" NPT Application System gold-plated contacts Application for industrial applications Media Liquids; water; glycol solutions; Coolants Note on media oil 1 with viscosity: 10 mm²/s (104 °F) oil 2 with viscosity: 46 mm²/s (104 °F) Medium temperature [°F] 14...212 Pressure rating [bar] 40 Pressure rating [Mpa] 4 MAWP (for applications according to CRN) [bar] 40 Electrical data Operating voltage Current consumption Protection class Reverse polarity protection [V] [mA] 18...30 DC; (to SELV/PELV) < 50 III yes ifm efector, inc. • 1100 Atwater Drive • Malvern • PA 19355 — We reserve the right to make technical alterations without prior notice. — EN-US — SBN234-00 — 26.07.2022 — SBN234 Flow meter with fast response and display SBN34IQ0FRKG Power-on delay time [s] 1 l/min; medium and operating temperature: +71,6 °F ± 4K) ± 1 % MEW ifm efector, inc. • 1100 Atwater Drive • Malvern • PA 19355 — We reserve the right to make technical alterations without prior notice. — EN-US — SBN234-00 — 26.07.2022 — SBN234 Flow meter with fast response and display SBN34IQ0FRKG Temperature monitoring Temperature drift 0,9802 °F / K Accuracy [K] 3 K (77 °F; Q > 1 l/min) Response time [s] 0.01 Damping process value dAP [s] 0...5 Damping for the analog output dAA [s] Reaction times Flow monitoring 0...5 Temperature monitoring Dynamic response T05 / T09 [s] T09 = 120 (Q > 1 l/min) Software / programming Parameter setting options hysteresis / window; normally open / closed; switching logic; current output; medium selection; damping for the switching output / analog output; display can be rotated and switched off; standard unit of measurement; process value color Interfaces Communication interface IO-Link Transmission type COM2 (38,4 kBaud) IO-Link revision 1.1 SDCI standard IEC 61131-9 CDV Profiles Smart Sensor: Process Data Variable; Device Identification SIO mode yes Required master port class A Process data analog 2 Process data binary 2 Min. process cycle time [ms] Supported DeviceIDs 5 Type of operation DeviceID default 567 Operating conditions Ambient temperature [°F] 32...140 Note on ambient temperature medium temperature < 176 °F medium temperature < 212 °F: 32...104 °F Storage temperature [°F] 5...176 Protection IP 65; IP 67 Tests / approvals EMC DIN EN 61000-6-2 DIN EN 61000-6-3 Shock resistance DIN EN 60068-2-27 20 g (11 ms) Vibration resistance DIN EN 60068-2-6 5 g (10...2000 Hz) MTTF [years] UL approval 145 UL approval number Pressure equipment directive I005 sound engineering practice; can be used for group 2 fluids; group 1 fluids on request Mechanical data Weight [g] 693 ifm efector, inc. • 1100 Atwater Drive • Malvern • PA 19355 — We reserve the right to make technical alterations without prior notice. — EN-US — SBN234-00 — 26.07.2022 — SBN234 Flow meter with fast response and display SBN34IQ0FRKG Material stainless steel (1.4404 / 316L); PBT+PC-GF30; PBT-GF20; PC; brass chemically nickel-plated Materials (wetted parts) stainless steel (1.4401 / 316); stainless steel (1.4404 / 316L); brass (2.0371); brass chemically nickel-plated; PPS; O-ring: FKM Process connection threaded connection 3/4" NPT Displays / operating elements Display Display unit 3 x LED, green Switching status 2 x LED, yellow Measured values alphanumeric display, red/green 4-digit Programming alphanumeric display, 4-digit Remarks Remarks Use of 200 micron filtration is recommended. All data refer to water (68 °F). MW = Measured value MEW = Final value of the measuring range Notes Please note the changed housing design! Pack quantity 1 pcs. Electrical connection Connector: 1 x M12; coding: A; Contacts: gold-plated ifm efector, inc. • 1100 Atwater Drive • Malvern • PA 19355 — We reserve the right to make technical alterations without prior notice. — EN-US — SBN234-00 — 26.07.2022 — SBN234 Flow meter with fast response and display SBN34IQ0FRKG Connection OUT1: OUT2: - Switching output Volumetric flow quantity monitoring Switching output Temperature monitoring Frequency output Volumetric flow quantity monitoring Frequency output Temperature monitoring IO-Link Switching output Volumetric flow quantity monitoring Switching output Temperature monitoring analog output Volumetric flow quantity monitoring analog output Temperature monitoring Colors to DIN EN 60947-5-2 Core colors : black brown blue white BK = BN = BU = WH = Diagrams and graphs Pressure loss dP Pressure loss Q volumetric flow quantity ifm efector, inc. • 1100 Atwater Drive • Malvern • PA 19355 — We reserve the right to make technical alterations without prior notice. — EN-US — SBN234-00 — 26.07.2022 —
SBN234 价格&库存
很抱歉,暂时无法提供与“SBN234”相匹配的价格&库存,您可以联系我们找货
