2D Drawing
IGES
STEP
3D PDF
Solder Profile
CofC RoHS Compliant
CofC REACH Compliant
UL Plastic File
Certificate of Origin
Check Stock
Request a Sample
Send Us An Email
Generated Part Number
KLDHCX-0202-A
Part Number Builder
R
E 140125
LR78160
KLDHCX-0202
DC POWER CONNECTORS: KLDHCX Series
Series
A
Diameter
High Current PCB Mount DC Power Jack
Product Features
2.0mm and 2.5mm
Built-In DC On/Off Switch
Laptop and Palm Computers, Portable Modems, Radar
Detectors, and Other Portable Device Applications
CSA/NRTL Certified File No. LR78160
Series
KLDHCX-0202 - High Current PCB Mount DC Power Jack
Diameter
A - 2.0mm Center Pin Diameter
B - 2.5mm Center Pin Diameter
Performance Specifications
Materials and Finish
Body: PBT, UL94V-0 Rated, Black Color
Contact Kycon For Other Option
Center Pin: Brass, Nickel Plated
Contact #1: Brass Tin Plated
Contact #2: Phosphor Bronze Tin Plated
Contact #3: Brass, Tin Plated
KLDHCX-0202 Series
Dimensions in mm
KLDHCX-0202-x
Electrical Characteristics
Rated Current: 5A
Rated Voltage: 24V RMS
Insulation Resistance: 50 Megohms Min. at
100 or 200V DC for 1 Minute
Contact Resistance: 30 milliohms Max.
Dielectric Withstanding Voltage: 250V AC Min. for 1 Minute
Mechanical Characteristics
Durability Test: 5000 Cycles
Insertion Force: 0.3kg - 2.5kg
Extraction Force: 0.3kg - 2.5kg
Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 0819
很抱歉,暂时无法提供与“KLDHCX-0202-B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+9.963251+1.28869
- 国内价格
- 1+12.40920
- 200+4.95720
- 500+4.79520
- 1000+4.70880
