2D Drawing
IGES
STEP
3D PDF
Solder Profile
CofC RoHS Compliant
CofC REACH Compliant
UL Plastic File
Certificate of Origin
Check Stock
Request a Sample
Send Us An Email
Generated Part Number
KLDVHCX-0202-A-LT
Part Number Builder
R
E 140125
LR78160
A
LT
Diameter
Type
KLDVHCX-0202
DC POWER CONNECTORS: KLDVHCX Series
Locking Type High Current Vertical PCB Mount DC Power Jack
Product Features
2.0mm and 2.5mm
Built in DC On/Off Switch
Locking Type
Mounts Perpendicular to PCB
Laptop and Palm Computers, Portable Modems, Radar
Detectors, and Other Portable Device Applications
CSA/NRTL Certified No. LR78160
UL File No. E140125
Performance Specifications
Materials and Finish
Body: PBT, UL94V-0 Rated, Color Black
Center Pin: Brass, Nickel Plated
Contact #1: Brass, Matte Tin Plated
Contact #2: Copper Alloy, Matte Tin Plated
Contact #3: Brass, Matte Tin Plated
Series
Series
KLDVHCX-0202 - High Current Vertical DC Power Jack
Diameter
A - 2.0mm Center Pin Diameter
B - 2.5mm Center Pin Diameter
Type
LT - Locking Type
Contact Kycon For Other Options
Recommended to be used with Kycon locking plug (tuning fork design):
KLDX-PA-0202-A-LT, KLDX-PA-0202-B-LT
If used with non-locking plug, tuning fork design
is required. See picture.
Tuning fork contact
Electrical Characteristics
Rated Current: 5A
Rated Voltage: 24V DC
Contact Resistance: 30 milliohms Max.
Insulation Resistance: 50 Megohms Min. at 100 or 200V
for 1 Minute
Dielectric Withstanding Voltage: 250V AC Min.
for 1 Minute
KLDVHCX Series
Dimensions in mm
KLDVHCX-0202-x-LT
Mechanical Characteristics
Durability Test: 5000 Cycles
Insertion Force: 3.0kg Max.
Extraction Force: 0.3kg Min.
Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 2013
很抱歉,暂时无法提供与“KLDVHCX-0202-B-LT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+8.904861+1.14880
- 10+7.5312710+0.97160
- 25+7.0624625+0.91112
- 50+6.7237550+0.86742
- 100+6.40275100+0.82601
- 250+6.00100250+0.77418
- 500+5.71436500+0.73720
- 1000+5.441581000+0.70201
- 2500+5.100902500+0.65806
