KLDVX-0202-B
KLDVX-0202-B
    KYCON
    套管 - 电源连接器 插孔 2.50mm 内径(0.098"),5.50mm 外径(0.217") 通孔
KLDVX-0202-B 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number KLDVX-0202-B Part Number Builder R E 140125 LR78160 B KLDVX-0202 DC POWER CONNECTORS: KLDVX Series Vertical PCB Mount DC Power Jack Product Features 2.0mm and 2.5mm Mounts Perpendicular to PCB Built in DC On/Off Switch CSA/NRTL Certified File No. LR78160 UL File No. E140125 Series Diameter Series KLDVX-0202 - Vertical PCB Mount DC Power Jack Diameter A - 2.0mm Center Pin Diameter B - 2.5mm Center Pin Diameter Contact Kycon For Other Options KLDVX-0202 Series Performance Specifications Materials and Finish Plastic Housing: High Temperature Thermoplastic, UL94V-0 Rated, Black Color Center Pin: Brass, Nickel Plated Contact #1: Brass, Matte Tin Plated Contact #2: Phosphor Bronze, Matte Tin Plated Contact #3: Brass, Matte Tin Plated Dimensions in mm Electrical Characteristics Contact Resistance Before Durability Test Between Terminals: 30 milliohms Max. Plug to Contacts: 50 milliohms Max. After Durability Test Between Terminals: 60 milliohms Max. Plug to Contacts: 100 milliohms Max. Rated Voltage: 24V DC Rated Current: 3.5A Insulation Resistance: 100 Megohms Min. Dielectric Withstanding Voltage: 500V AC RMS for 1 Minute Mechanical Characteristics Durability Test: 5000 Cycles Insertion Force: 0.3kg - 2.0kg Extraction Force: 0.3kg - 2.0kg Operating Temperature: -25˚C to +85˚C Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 0321
KLDVX-0202-B 价格&库存
很抱歉,暂时无法提供与“KLDVX-0202-B”相匹配的价格&库存,您可以联系我们找货
KLDVX-0202-B
    • 1+7.92720
    • 200+3.16440
    • 500+3.05640
    • 1000+3.01320
