2D Drawing
IGES
STEP
3D PDF
Solder Profile
CofC RoHS Compliant
CofC REACH Compliant
UL Plastic File
Certificate of Origin
Check Stock
Request a Sample
Send Us An Email
Generated Part Number
KLDX-SMT-0201L-ATR
Part Number Builder
R
E 140125
LR78160
DC POWER CONNECTORS: KLDX-SMT Series
Surface Mount Mini DC Power Jack
KLDX-SMT-0201L
Series
A
TR
Diameter
Packaging
Option
Contact Kycon For Other Option
Series
KLDX-SMT-0201L - Surface Mount Mini DC Power Jack
Product Features
1.0mm and 1.3mm
Built-In DC On/Off Switch
Laptop and Palm Computer, Portable Modems, Radar
Detectors, and Other Portable Device Applications
High Temperature Material For Reflow Compatibility
Packaged in Tape & Reel for Automated Assembly
CSA/NRTL Certified File No. LR78160
UL File No. E140125
Diameter
A - 1.0mm Center Pin Diameter
B - 1.3mm Center Pin Diameter
Packaging Option
TR - Tape and Reel
Contact Kycon for Other Options
KLDX-SMT-0201L
Dimensions in mm
Performance Specifications
Materials and Finish
Plastic Housing: High Temperature Thermoplastic,
UL94V-0 Rated, Black Color
Center Pin: Copper Alloy, Nickel Plated
Contacts: Copper Alloy, Silver Plated
Electrical Characteristics
Contact Resistance
Before Durability Test
Between Terminals: 30 milliohms Max.
Plug to Contacts: 50 milliohms Max.
After Durability Test
Between Terminals: 60 milliohms Max.
Plug to Contacts: 100 milliohms Max.
Rated Voltage: 24V DC
Rated Current: 3.0A
Insulation Resistance: 100 Megohms Min.
Dielectric Withstanding Voltage:
500V AC RMS for 1 Minute
Mechanical Characteristics
Durability Test: 5000 Cycles
Insertion Force: 0.3kg - 2.0kg
Extraction Force: 0.3kg - 2.0kg
Operating Temperature: -25˚C to +85˚C
Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 2013
很抱歉,暂时无法提供与“KLDX-SMT-0201L-ATR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+19.69920
- 200+7.86240
- 500+7.60320
- 800+7.47360
