KLDX-SMT-0201L-BTR
KLDX-SMT-0201L-BTR
    KYCON
    SMD
    套管 - 电源连接器 插孔 1.30mm 内径(0.051"),3.50mm 外径(0.138") 表面贴装,直角
KLDX-SMT-0201L-BTR 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number KLDX-SMT-0201L-ATR Part Number Builder R E 140125 LR78160 DC POWER CONNECTORS: KLDX-SMT Series Surface Mount Mini DC Power Jack KLDX-SMT-0201L Series A TR Diameter Packaging Option Contact Kycon For Other Option Series KLDX-SMT-0201L - Surface Mount Mini DC Power Jack Product Features 1.0mm and 1.3mm Built-In DC On/Off Switch Laptop and Palm Computer, Portable Modems, Radar Detectors, and Other Portable Device Applications High Temperature Material For Reflow Compatibility Packaged in Tape & Reel for Automated Assembly CSA/NRTL Certified File No. LR78160 UL File No. E140125 Diameter A - 1.0mm Center Pin Diameter B - 1.3mm Center Pin Diameter Packaging Option TR - Tape and Reel Contact Kycon for Other Options KLDX-SMT-0201L Dimensions in mm Performance Specifications Materials and Finish Plastic Housing: High Temperature Thermoplastic, UL94V-0 Rated, Black Color Center Pin: Copper Alloy, Nickel Plated Contacts: Copper Alloy, Silver Plated Electrical Characteristics Contact Resistance Before Durability Test Between Terminals: 30 milliohms Max. Plug to Contacts: 50 milliohms Max. After Durability Test Between Terminals: 60 milliohms Max. Plug to Contacts: 100 milliohms Max. Rated Voltage: 24V DC Rated Current: 3.0A Insulation Resistance: 100 Megohms Min. Dielectric Withstanding Voltage: 500V AC RMS for 1 Minute Mechanical Characteristics Durability Test: 5000 Cycles Insertion Force: 0.3kg - 2.0kg Extraction Force: 0.3kg - 2.0kg Operating Temperature: -25˚C to +85˚C Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 2013
KLDX-SMT-0201L-BTR 价格&库存
很抱歉,暂时无法提供与“KLDX-SMT-0201L-BTR”相匹配的价格&库存,您可以联系我们找货
KLDX-SMT-0201L-BTR
    • 800+8.21751800+1.06220
    库存:6400
    KLDX-SMT-0201L-BTR
    • 1+15.098211+1.95161
    • 10+12.8302710+1.65845
    • 25+12.0230425+1.55411
    • 50+11.4490150+1.47991
    • 100+10.90242100+1.40926
    • 250+10.21878250+1.32089
    库存:21600
    KLDX-SMT-0201L-BTR
    • 800+9.41354800+1.21680
    • 1600+8.964261600+1.15873
    • 2400+8.711562400+1.12607
    • 4000+8.403394000+1.08623
    • 5600+8.206455600+1.06077
    • 8000+8.002698000+1.03444
    库存:21600
