GDTX-S-88
GDTX-S-88
    KYCON
    插件
    模块化连接器 - 插孔 8p8c(RJ45,以太网) 垂直 屏蔽式,EMI指 Cat5
GDTX-S-88 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number GDTX-S-88 Part Number Builder LR78160 MODULAR JACKS AND PLUGS: GDTX Series Vertical CAT5 Modular Jack Product Features Fully Shielded to Reduce EMI/RFI Snap in Board Retention Tabs CSA/NRTL Certified File No. LR78160 Fully Shielded for Category 5 Application Performance Specifications Materials and Finish Housing Material PBT Thermoplastic, UL 94V-0 Rated, Gray Color Shield Material Copper Alloy, Nickel Plated Contact Material Phosphor Bronze Electrical Characteristics GDTX S 88 Series Shield Positions & Contacts Plating Option Series GDTX - Vertical CAT5 Modular Jack Shield S - Shielded Number of Positions / Contacts 88 - 8 Positions / 8 Contacts Plating Option Blank - Gold Flash 50 - 50µ" Gold Plating Contact Kycon for Other Options GDTX Series Dimensions in mm GDTX-S-88 Insulation Resistance 500 Megohms Min. Dielectric Withstanding Voltage 1000V RMS for 1 Minute Contact Resistance 20 milliohms Max. Current Rating 1.5A Voltage Rating 125V DC Operating Temperature -40°C to +85°C Durability 500 Mating Cycles Min. Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 2013
GDTX-S-88 价格&库存
很抱歉,暂时无法提供与“GDTX-S-88”相匹配的价格&库存,您可以联系我们找货
GDTX-S-88
    库存:2300
