KLP42X-61-WW/RR
KLP42X-61-WW/RR
    KYCON
    3.20mm 内径,9.00mm 外径(RCA) 音频(RCA)插孔 单声道 连接器 焊接
KLP42X-61-WW/RR 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number KLP42X-61-BB/BB Part Number Builder LR78160 RCA PHONO JACKS: KLP42X Series KLP42X 61 BB/BB Series Type Color Option Stacked RCA Phono Jack PCB Mount Product Features Audio Applications for Computers and Multimedia Gold Plating Available Upon Request Various Color and Stacking Options Available CSA/NRTL Certified File No. LR78160 Performance Specifications Materials and Finish Housing PBT Thermoplastic, UL94V-0 Rated Terminals Brass,Tin Plated Ground Pin Brass,Nickel Plated Electrical Characteristics Rated Current: 0.3A Rated Voltage: 16V DC Contact Resistance 50 milliohms Max. Insulation Resistance 100 Megohms Min. at 500V DC Dielectric Withstanding Voltage 500V AC RMS for 1 Minute Series KLP42X - Stacked RCA Phono Jack Type 61 - Double Column, Double Row Color Option BB/BB - Black, Black / Black, Black RR/WW - Red, Red / White, White RW/RW - Red, White / Red, White WB/RY - White, Black / Red, Yellow WR/BB - White, Red / Black, Black WR/WR - White, Red / White, Red WW/RR - White, White / Red, Red WW/WW - White, White / White, White YW/YW - Yellow, White / Yellow, White YY/WW - Yellow, Yellow / White, White YY/YY - Yellow, Yellow / Yellow, Yellow Color layout X, X1 / Z, Z1 Contact Kycon for other options KLP42X-61-xx/xx Dimensions in mm Mechanical Characteristics Insertion Force 0.3kg - 5.0kg Extraction Force 0.3kg - 5.0kg Durability 1000 Mating Cycles Min. Operating Temperature -20°C to +60°C X1 X Z Z1 Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 2013
KLP42X-61-WW/RR 价格&库存
很抱歉,暂时无法提供与“KLP42X-61-WW/RR”相匹配的价格&库存,您可以联系我们找货
KLP42X-61-WW/RR
    • 1+26.09280
    • 200+10.41120
    • 480+10.06560
    • 1000+9.89280
