KUSBVX-AS2N-B-1
KUSBVX-AS2N-B-1
    KYCON
    插件
    USB连接器 8P 插件 端口数:2 额定电流:1A 额定电压:30V 工作温度:-55℃~+85℃
KUSBVX-AS2N-B-1 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number KUSBVX-AS2N-B-1 Part Number Builder KUSBVX UNIVERSAL SERIAL BUS: KUSBVX Series Vertical Top Entry USB Series AS2N Type B Insulator Color Option Plating Option Series KUSBVX - Vertical Top Entry Universal Serial Bus Product Features Vertical Top Entry Compatible with Many Computer Peripherals A Type Supports Hot Plugging Contact Area with Gold Plating Performance Specifications Materials and Finish Insulator PBT Thermoplastic, UL 94V-0 Rated, Color White/Black Contacts Phosphor Bronze Plating Options: Standard - Gold Flash on contact Area, Tin on Solder Tail, all over Nickel 30 Option - 30µ” Gold on Contacts Area, Tin Solder Tail, all over Nickel Shell Brass, Nickel Plated Type AS2N - Stacked A Type Insulator Color Option B - Black W - White Plating Option Blank - Gold Flash 30 - 30µ" Gold Plating Contact Kycon for other options KUSBVX Series Dimensions in mm KUSBVX-AS2N Electrical Characteristics Rated Voltage: 30V AC (rms) Contact Current Rating : 1A Max. Contact Resistance: 30 milliohms Max. Insulation Resistance: 1000 Megohms Min. Dielectric Withstanding: 750V AC Mechanical Characteristics Insertion Force: 3.57kg Max. Extraction Force: 1.02kg Min. OperatingTemperature: Durability: 1500 Mating Cycles Min. Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 0319
KUSBVX-AS2N-B-1 价格&库存
很抱歉,暂时无法提供与“KUSBVX-AS2N-B-1”相匹配的价格&库存,您可以联系我们找货
