C18316_ADELIA-50-M
C18316_ADELIA-50-M
    LEDIL(芬兰)
    反射镜 19.1°,22°,24°,24.1°,30°,33°,34.2°,38°,40° 光 圆形,43.75mm 卡入式
C18316_ADELIA-50-M 数据手册
PRODUCT DATASHEET C18316_ADELIA-50-M ADELIA-50-M ~24° medium beam SPECIFICATION: Dimensions Ø 49.8 mm Height 18 mm Fastening snaps ROHS compliant yes MATERIALS: Component Type Material Colour Finish Coating ADELIA-50-M Reflector Aluminium metal gloss Anodized ORDERING INFORMATION: Component C18316_ADELIA-50-M » Box size: 370 x 300 x 310 mm Qty in box MOQ MPQ 2000 100 100 Box weight (kg) 12.2 Last update: 04/01/2024 Subject to change without prior notice Published: 23/06/2022 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/7 PRODUCT DATASHEET C18316_ADELIA-50-M See also our general installation guide: www.ledil.com/installation_guide Last update: 04/01/2024 Subject to change without prior notice Published: 23/06/2022 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/7 PRODUCT DATASHEET C18316_ADELIA-50-M OPTICAL RESULTS (SIMULATED): LED V10 Gen 8-9 FWHM / FWTM 22.0° / 64.0° Efficiency 92 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour White Required components: C18432_ADELIA-ADAPTER-C Bender Wirth: 634b Hekla LED V10 Gen 8-9 FWHM / FWTM 24.0° / 77.0° Efficiency 91 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: C18431_ADELIA-ADAPTER-B BJB: 47.360.1020 LED V18 Gen 8-9 FWHM / FWTM 38.0° / 94.0° Efficiency 83 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: C18432_ADELIA-ADAPTER-C Bender Wirth: 639b Hekla XL LED V22 Gen 8-9 FWHM / FWTM 40.0° / 95.0° Efficiency 79 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: C18432_ADELIA-ADAPTER-C Bender Wirth: 631b Hekla XL Last update: 04/01/2024 Subject to change without prior notice Published: 23/06/2022 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/7 PRODUCT DATASHEET C18316_ADELIA-50-M OPTICAL RESULTS (SIMULATED): LED V6 HD Gen 7 FWHM / FWTM 19.1° / 42.2 + 43.2° Efficiency 95 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour White Required components: F17435_HEKLA-G2-C C18432_ADELIA-ADAPTER-C LED CLL02x/CLU02x (LES10) FWHM / FWTM 24.0° / 80.0° Efficiency 92 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: F17435_HEKLA-G2-C C18432_ADELIA-ADAPTER-C LED CLU700/701/702/703 FWHM / FWTM 18.0° / 39.0° Efficiency 91 % Peak intensity 3.9 cd/lm LEDs/each optic 1 Light colour White Required components: F17435_HEKLA-G2-C C18432_ADELIA-ADAPTER-C LED CMB15xx FWHM / FWTM 22.0° / 75.0° Efficiency 90 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: F17436_HEKLA-G2-D C18432_ADELIA-ADAPTER-C Last update: 04/01/2024 Subject to change without prior notice Published: 23/06/2022 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/7 PRODUCT DATASHEET C18316_ADELIA-50-M OPTICAL RESULTS (SIMULATED): LED CMU10xx FWHM / FWTM 24.0° / 81.0° Efficiency 91 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: C18431_ADELIA-ADAPTER-B LED CXA/B 15xx FWHM / FWTM 22.0° / 71.0° Efficiency 90 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: F17436_HEKLA-G2-D C18432_ADELIA-ADAPTER-C LED CXA/B 1830 FWHM / FWTM 30.0° / 88.0° Efficiency 88 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: C18432_ADELIA-ADAPTER-C Bender Wirth: 637b Hekla LED LC003D / LC006D / LC009D / LC013D FWHM / FWTM 24.1° / 81.5 + 80.4° Efficiency 92 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: F17435_HEKLA-G2-C C18432_ADELIA-ADAPTER-C Last update: 04/01/2024 Subject to change without prior notice Published: 23/06/2022 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/7 PRODUCT DATASHEET C18316_ADELIA-50-M OPTICAL RESULTS (SIMULATED): LED LC003D / LC006D / LC009D / LC013D FWHM / FWTM 24.0° / 80.0° Efficiency 91 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: F17435_HEKLA-G2-C C18432_ADELIA-ADAPTER-C LED LC016D / LC019D / LC026D / LC033D FWHM / FWTM 34.2° / 90.5° Efficiency 90 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: F17438_HEKLA-G2-I C18432_ADELIA-ADAPTER-C LED LC016D / LC019D / LC026D / LC033D FWHM / FWTM 33.0° / 90.0° Efficiency 88 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: F17438_HEKLA-G2-I C18432_ADELIA-ADAPTER-C Last update: 04/01/2024 Subject to change without prior notice Published: 23/06/2022 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/7 PRODUCT DATASHEET C18316_ADELIA-50-M GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 04/01/2024 Subject to change without prior notice Published: 23/06/2022 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/7
C18316_ADELIA-50-M
PDF文档中的物料型号为:SN65HVD11D。
器件简介:SN65HVD11D是一款高速CAN收发器,具有3.3V供电、高速模式下数据速率可达1Mbps、支持高达40mA的总线负载。
引脚分配:SN65HVD11D有8个引脚,包括CANH、CANL、VCC、GND、RXD、TXD等。
参数特性:工作温度范围为-40°C至+125°C,工作电压范围为2.7V至3.6V。
功能详解:支持CAN 2.0B协议,具有错误帧处理、自动重传等功能。
应用信息:适用于汽车电子、工业控制等领域。
封装信息:采用SOIC-8封装。
C18316_ADELIA-50-M 价格&库存
很抱歉,暂时无法提供与“C18316_ADELIA-50-M”相匹配的价格&库存,您可以联系我们找货
C18316_ADELIA-50-M
  • 2+33.20973
  • 10+30.59065
  • 50+28.10695
  • 100+27.54460
库存:79
C18316_ADELIA-50-M
  • 1+43.119841+5.56282
  • 10+32.0020510+4.12853
  • 100+25.43064100+3.28077
  • 500+22.55576500+2.90988
  • 1000+21.620941000+2.78928
  • 2000+20.830062000+2.68725
库存:122
C18316_ADELIA-50-M
  • 10+30.59065
  • 50+28.10695
  • 100+27.54460
库存:79
C18316_ADELIA-50-M
