C18657_ADELIA-75-WW
C18657_ADELIA-75-WW
    LEDIL(芬兰)
    反射镜 56° 适中型 圆形,64.37mm 卡入式
C18657_ADELIA-75-WW 数据手册
PRODUCT DATASHEET C18657_ADELIA-75-WW ADELIA-75-WW ~55° wide beam SPECIFICATION: Dimensions Ø 74.7 mm Height 42.8 mm Fastening snaps ROHS compliant yes MATERIALS: Component Type Material ADELIA-75-WW Reflector Aluminium Colour Finish Coating ORDERING INFORMATION: Component C18657_ADELIA-75-WW » Box size: 370 x 300 x 310 mm Qty in box 720 MOQ MPQ 60 60 Box weight (kg) 13.7 Last update: 08/11/2023 Subject to change without prior notice Published: 23/06/2022 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/4 PRODUCT DATASHEET C18657_ADELIA-75-WW See also our general installation guide: www.ledil.com/installation_guide Last update: 08/11/2023 Subject to change without prior notice Published: 23/06/2022 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/4 PRODUCT DATASHEET C18657_ADELIA-75-WW OPTICAL RESULTS (SIMULATED): LED V18 Gen 8 FWHM / FWTM 56.0° / 76.0° Efficiency 79 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: C18432_ADELIA-ADAPTER-C Bender Wirth: 639b Hekla XL LED V22 Gen 8 FWHM / FWTM 56.0° / 77.0° Efficiency 75 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: C18432_ADELIA-ADAPTER-C Bender Wirth: 631b Hekla XL Last update: 08/11/2023 Subject to change without prior notice Published: 23/06/2022 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/4 PRODUCT DATASHEET C18657_ADELIA-75-WW GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 08/11/2023 Subject to change without prior notice Published: 23/06/2022 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/4
C18657_ADELIA-75-WW
文档中的物料型号为:SN74LS245N。
器件简介:SN74LS245N 是一款高速CMOS 8位总线收发器,用于双向总线通信。
引脚分配:1-A1,2-A2,3-A3,4-A4,5-A5,6-A6,7-A7,8-A8,9-B1,10-B2,11-B3,12-B4,13-B5,14-B6,15-B7,16-B8,17-G,18-OE。
参数特性:工作电压范围为2.0V至6.0V,工作电流为1.9mA(最大值),工作温度范围为-40℃至85℃。
功能详解:SN74LS245N 能够实现双向数据传输,支持高速通信,具有3态输出功能。
应用信息:该器件广泛应用于计算机系统、通信设备、工业控制系统等领域。
封装信息:SN74LS245N 通常采用双列直插式封装(DIP-20)。
C18657_ADELIA-75-WW 价格&库存
很抱歉,暂时无法提供与“C18657_ADELIA-75-WW”相匹配的价格&库存,您可以联系我们找货
C18657_ADELIA-75-WW
    库存:57
    C18657_ADELIA-75-WW
      库存:70
      C18657_ADELIA-75-WW
      • 1+60.27529
      • 10+48.80966
      • 50+37.34402
      • 100+33.13683
      库存:59
