C18806_DAISY-7X1-BW
C18806_DAISY-7X1-BW
    LEDIL(芬兰)
    透镜 透明 宽型 卡入式
C18806_DAISY-7X1-BW 数据手册
PRODUCT DATASHEET DAISY-7X1-BW DAISY-7X1-BW ~80° batwing beam SPECIFICATION: Dimensions 40.0 x 259.0 mm Height 40 mm ROHS compliant yes MATERIALS: Component Type Material Colour Finish C18806_DAISY-7X1-BW Multi-lens PMMA clear C18409_DAISY-7X1-SHD-MET-MATT Shade PC metal matt C18167_DAISY-7X1-SHD-MET Shade PC metal gloss C17225_DAISY-7X1-SHD-WHT-MATT Shade PC white matt C17051_DAISY-7X1-SHD-MATT Shade PC black matt C16876_DAISY-7X1-SHD-WHT Shade PC white gloss C16872_DAISY-7X1-SHD Shade PC black gloss ORDERING INFORMATION: Quantities for one set: Multi-lens 1 Shade 1 Last update: 16/11/2023 Subject to change without prior notice Published: 10/03/2023 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/9 PRODUCT DATASHEET DAISY-7X1-BW Component Qty in box MOQ MPQ Box weight (kg) C18806_DAISY-7X1-BW » Box size: 400 x 300 x 300 mm Multi-lens 312 312 24 5.7 C17225_DAISY-7X1-SHD-WHT-MATT » Box size: 595 x 360 x 230 mm Shade 156 312 24 7.6 C16872_DAISY-7X1-SHD » Box size: 595 x 360 x 230 mm Shade 156 312 24 7.1 C18167_DAISY-7X1-SHD-MET » Box size: 595 x 360 x 230 mm Shade 156 312 24 7.0 C16876_DAISY-7X1-SHD-WHT » Box size: 595 x 360 x 230 mm Shade 156 312 24 7.6 C18409_DAISY-7X1-SHD-MET-MATT » Box size: 595 x 360 x 230 mm Shade 156 312 24 7.0 C17051_DAISY-7X1-SHD-MATT » Box size: 595 x 360 x 230 mm Shade 156 312 24 7.3 Last update: 16/11/2023 Subject to change without prior notice Published: 10/03/2023 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/9 PRODUCT DATASHEET DAISY-7X1-BW Last update: 16/11/2023 Subject to change without prior notice Published: 10/03/2023 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/9 PRODUCT DATASHEET DAISY-7X1-BW See also our general installation guide: www.ledil.com/installation_guide Last update: 16/11/2023 Subject to change without prior notice Published: 10/03/2023 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/9 PRODUCT DATASHEET DAISY-7X1-BW OPTICAL RESULTS (MEASURED): LED LLE 20x280mm 750lm 827-865 LV MD ADV1 FWHM / FWTM Asymmetric Efficiency 78 % Peak intensity 0.5 cd/lm LEDs/each optic 4 Light colour Tunable White Required components: C16872_DAISY-7X1-SHD Last update: 16/11/2023 Subject to change without prior notice Published: 10/03/2023 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/9 PRODUCT DATASHEET DAISY-7X1-BW OPTICAL RESULTS (SIMULATED): LED LUXEON 2835 Line FWHM / FWTM 75.0 + 78.0° / 92.0 + 94.0° Efficiency 89 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: C16872_DAISY-7X1-SHD LED LinLED 280x20mm 1100lm 8x0 2C 42V Opt G1 FWHM / FWTM 78.0° / 94.0° Efficiency 87 % Peak intensity 0.6 cd/lm LEDs/each optic 2 Light colour White Required components: C16872_DAISY-7X1-SHD LED LinLED 280x20mm 1100lm 8x0 2C 42V Opt G1 FWHM / FWTM 78.0° / 94.0° Efficiency 87 % Peak intensity 0.6 cd/lm LEDs/each optic 2 Light colour White Required components: C17051_DAISY-7X1-SHD-MATT LED LinLED 280x20mm 1100lm 8x0 2C 42V Opt G1 FWHM / FWTM 78.0° / 94.0° Efficiency 90 % Peak intensity 0.6 cd/lm LEDs/each optic 2 Light colour White Required components: C16876_DAISY-7X1-SHD-WHT Last update: 16/11/2023 Subject to change without prior notice Published: 10/03/2023 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/9 PRODUCT DATASHEET DAISY-7X1-BW OPTICAL RESULTS (SIMULATED): LED LinLED 280x28mm 1100lm 8x0 2C 42V Opt G1 FWHM / FWTM 77.0° / 94.0° Efficiency 90 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: C17225_DAISY-7X1-SHD-WHT-MATT LED Duris E 2835 FWHM / FWTM 76.0 + 79.0° / 92.0 + 96.0° Efficiency 88 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: C16872_DAISY-7X1-SHD LED Duris E 2835 FWHM / FWTM 77.0° / 94.0° Efficiency 88 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: C17051_DAISY-7X1-SHD-MATT LED Duris E 2835 FWHM / FWTM 77.0° / 94.0° Efficiency 90 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: C17225_DAISY-7X1-SHD-WHT-MATT Last update: 16/11/2023 Subject to change without prior notice Published: 10/03/2023 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/9 PRODUCT DATASHEET DAISY-7X1-BW OPTICAL RESULTS (SIMULATED): LED LLE 24x280mm 750lm 8x0 LVD ADV1 FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: C17051_DAISY-7X1-SHD-MATT LED LLE 24x280mm 750lm 8x0 LVD ADV1 FWHM / FWTM Asymmetric Efficiency 89 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: C17225_DAISY-7X1-SHD-WHT-MATT Last update: 16/11/2023 Subject to change without prior notice Published: 10/03/2023 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/9 PRODUCT DATASHEET DAISY-7X1-BW GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 16/11/2023 Subject to change without prior notice Published: 10/03/2023 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/9
C18806_DAISY-7X1-BW 价格&库存
很抱歉,暂时无法提供与“C18806_DAISY-7X1-BW”相匹配的价格&库存,您可以联系我们找货
C18806_DAISY-7X1-BW
