C16369_HB-SQ-W
C16369_HB-SQ-W
    LEDIL(芬兰)
    透镜 透明 53° ~ 65° 适中型 胶合剂
C16369_HB-SQ-W 数据手册
PRODUCT DATASHEET C16369_HB-SQ-W HB-SQ-W ~60° beam SPECIFICATION: Dimensions Height Fastening ROHS compliant 25.0 x 25.0 mm 9.8 mm glue, pin, screw yes MATERIALS: Component Type Material Colour HB-SQ-W Single lens PMMA clear Finish ORDERING INFORMATION: Component C16369_HB-SQ-W » Box size: 480 x 280 x 300 mm Qty in box MOQ MPQ 2058 294 98 Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 8.4 1/6 PRODUCT DATASHEET C16369_HB-SQ-W See also our general installation guide: www.ledil.com/installation_guide Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/6 PRODUCT DATASHEET C16369_HB-SQ-W OPTICAL RESULTS (SIMULATED): LED XHP50.2 FWHM / FWTM 60.0° / 94.0° Efficiency 96 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP50.3 HD FWHM / FWTM 61.0° / 95.0° Efficiency 95 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP70 FWHM / FWTM 57.0° / 92.0 + 90.0° Efficiency 93 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP70.2 FWHM / FWTM 65.0° / 98.0° Efficiency 91 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/6 PRODUCT DATASHEET C16369_HB-SQ-W OPTICAL RESULTS (SIMULATED): LED XHP70.3 HD FWHM / FWTM 64.0° / 99.0° Efficiency 95 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 7070 FWHM / FWTM 51.0° / 86.0° Efficiency 96 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON M/MX FWHM / FWTM 54.0° / 87.0 + 84.0° Efficiency 93 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON MZ FWHM / FWTM 51.0° / 81.0° Efficiency 96 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/6 PRODUCT DATASHEET C16369_HB-SQ-W OPTICAL RESULTS (SIMULATED): LED NV4x144A FWHM / FWTM 62.0° / 96.0° Efficiency 96 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris S10 FWHM / FWTM 48.0° / 82.0° Efficiency 95 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 7070 FWHM / FWTM 53.0° / 85.0° Efficiency 94 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED SFH 4717AS FWHM / FWTM 44.0° / 68.0° Efficiency 96 % LEDs/each optic 1 Light colour IR Required components: Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/6 PRODUCT DATASHEET C16369_HB-SQ-W GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 08/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/6
C16369_HB-SQ-W
1. 物料型号: C16369_HB-SQ-W 2. 器件简介: - 产品类型: HighBay - 光束角度: ~60° - 尺寸: 25.0 x 25.0 mm,高度9.8 mm,包含胶水、引脚、螺丝 - 固定方式: 是 - 符合RoHS标准 3. 引脚分配: 未在文档中明确提及 4. 参数特性: - 光学模拟结果展示了不同LED芯片的FWHM/FWTM角度和效率,例如CREE XHP50.2、XHP70.3 HD、LUMILEDS LUXEON 7070等 - 光色: 白色 - 需要的组件: 每个光学元件所需的LED数量 5. 功能详解: - 光学模拟结果提供了不同LED的效率和峰值强度 - 提供了一般安装指南的链接: [www.ledil.com/installation_guide](http://www.ledil.com/installation_guide) 6. 应用信息: 适用于高棚照明 7. 封装信息: - 材料: PMMA - 颜色/涂层: 透明 - 订购信息包括每箱数量、最小起订量(MOQ)、中等起订量(MPQ)和箱重
C16369_HB-SQ-W 价格&库存
很抱歉,暂时无法提供与“C16369_HB-SQ-W”相匹配的价格&库存,您可以联系我们找货
