PRODUCT
DATASHEET
CA16755_IRIE-A
IRIE-A
~120° x 90° rectangle beam for 4:3 aspect ratio
cameras. Assembly with tape.
SPECIFICATION:
Dimensions
Height
Fastening
ROHS compliant
14.0 x 14.0 mm
5.1 mm
tape, pin
yes
MATERIALS:
Component
Type
Material
Colour
IRIE-A
Single lens
PMMA
clear
VERONICA-SQ-MINI-TAPE
Tape
Acrylic foam
clear
Finish
ORDERING INFORMATION:
Component
CA16755_IRIE-A
» Box size: 480 x 280 x 300 mm
Single lens
Qty in box
MOQ
MPQ
5544
252
252
Box weight (kg)
5.5
Last update: 08/11/2023
Subject to change without prior notice
Published: 05/11/2018
LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries.
1/5
PRODUCT
DATASHEET
CA16755_IRIE-A
See also our general installation guide: www.ledil.com/installation_guide
2/5
PRODUCT
DATASHEET
CA16755_IRIE-A
OPTICAL RESULTS (MEASURED):
LED
LUXEON IR 2720
FWHM / FWTM
Asymmetric
Efficiency
LEDs/each optic
1
Light colour
IR
Required components:
LED
LUXEON Z
FWHM / FWTM
Asymmetric
Efficiency
94 %
Peak intensity
1.5 cd/lm
LEDs/each optic
1
Light colour
White
3/5
PRODUCT
DATASHEET
CA16755_IRIE-A
OPTICAL RESULTS (SIMULATED):
LED
LUXEON IR 2720
FWHM / FWTM
Asymmetric
Efficiency
92 %
LEDs/each optic
1
Light colour
IR
LED
LUXEON IR Compact
FWHM / FWTM
Asymmetric
Efficiency
93 %
LEDs/each optic
1
Light colour
White
LED
SFH 4770S
FWHM / FWTM
Asymmetric
Efficiency
93 %
LEDs/each optic
1
Light colour
White
4/5
PRODUCT
DATASHEET
CA16755_IRIE-A
GENERAL INFORMATION:
NOTE: The typical beam angle will be changed by different color, chip size
and chip position tolerance. The typical total beam angle is the full angle
measured where the luminous intensity is half of the peak value.
MATERIALS:
As part of our continuous research and improvement processes, and to ensure
the best possible quality and availability of our products, LEDiL reserves the
right to change material grades without notice.
PRODUCT DATA USER AGREEMENT AND DISCLAIMER:
The measured data in the provided downloadable LEDiL Product Datasheets
and Mechanical 2D-Drawings is rounded and provided as reference for
planning. LEDiL Oy's optical specifications have been verified by conducting
performance testing of the products in accordance with the company's quality
system. The reported data are averaged results of multiple measurements with
typical variation. LEDiL Oy reserves the right to without prior notification make
changes and improvements to its products.
LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of
any kind for the contents and correctness of the provided data. The provided
data has been generated with highest diligence but the provided data may in
reality not represent the complete possible variation range of all intrinsic
parameters. Therefore, in certain cases a deviation from the provided data
could occur.
LEDiL Oy
Joensuunkatu 13
FI-24240 SALO
Finland
LEDiL Inc.
228 West Page Street
Suite D
Sycamore IL 60178
USA
Ledil Optics Technology
(Shenzhen) Co., Ltd.
# 405 , Block B
Casic Motor Building
Shenzhen 518057
P.R.CHINA
Local sales and technical
support
www.ledil.com/
where_to_buy
Shipping locations
Salo, Finland
Hong Kong, China
Distribution Partners
www.ledil.com/
where_to_buy
LEDiL Oy reserves the right to undertake technical changes of its products
without further notification which could lead to changes in the provided data.
LEDiL Oy assumes no liability of any kind for the possible deviation from any
provided data or any other damage resulting from the usage of the provided
data.
The user agrees to this disclaimer and user agreement with the download or
usage of the provided files.
5/5
很抱歉,暂时无法提供与“CA16755_IRIE-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+12.175351+1.56317
- 10+8.6390610+1.10916
- 252+5.88218252+0.75521
- 504+5.51398504+0.70793
- 1008+5.201281008+0.66779
- 2016+4.936152016+0.63375
- 5040+4.646855040+0.59660
- 10080+4.4667010080+0.57348
