C17411_SPORT-2X2-S2
C17411_SPORT-2X2-S2
    LEDIL(芬兰)
    MULTI-LENS4 POSMM (D)
C17411_SPORT-2X2-S2 数据手册
PRODUCT DATASHEET C17411_SPORT-2X2-S2 SPORT-2X2-S2 Slightly asymmetric minimum spill light ~20° spot beam with SPECIFICATION: Dimensions Height 50.0 x 50.0 mm 14.2 mm Fastening screw ROHS compliant yes MATERIALS: Component Type Material Colour SPORT-2X2-S2 Multi-lens PMMA clear Finish ORDERING INFORMATION: Component C17411_SPORT-2X2-S2 » Box size: 480 x 280 x 300 mm Qty in box 476 MOQ MPQ 140 28 Box weight (kg) 10.5 Last update: 31/01/2024 Subject to change without prior notice Published: 07/07/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/21 PRODUCT DATASHEET C17411_SPORT-2X2-S2 See also our general installation guide: www.ledil.com/installation_guide Last update: 31/01/2024 Subject to change without prior notice Published: 07/07/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/21 PRODUCT DATASHEET C17411_SPORT-2X2-S2 OPTICAL RESULTS (MEASURED): LED XP-G4 FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 7.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON HL2X FWHM / FWTM Asymmetric Efficiency 97 % Peak intensity 6.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON HL2X FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 6.8 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED OSCONIQ C 3030 FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 8.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 31/01/2024 Subject to change without prior notice Published: 07/07/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/21 PRODUCT DATASHEET C17411_SPORT-2X2-S2 OPTICAL RESULTS (MEASURED): LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM Asymmetric Efficiency 97 % Peak intensity 8.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 7.9 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED PassivePAQ-R-222x50.OS1.9.7K-750-5 V1.0 FWHM / FWTM Asymmetric Efficiency 97 % Peak intensity 7.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED PassivePAQ-R-274x51-NI0-21K-857-5 FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 4.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 31/01/2024 Subject to change without prior notice Published: 07/07/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/21 PRODUCT DATASHEET C17411_SPORT-2X2-S2 OPTICAL RESULTS (SIMULATED): LED J Series 5050 Round LES FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 3.6 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED J Series 5050 Round LES FWHM / FWTM Asymmetric Efficiency 97 % Peak intensity 3.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED J Series 5050C 6V E Class FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 3.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP35.2 HD FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 31/01/2024 Subject to change without prior notice Published: 07/07/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/21 PRODUCT DATASHEET C17411_SPORT-2X2-S2 OPTICAL RESULTS (SIMULATED): LED XHP35.2 HD FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED XHP35.2 HI FWHM / FWTM Asymmetric Efficiency 87 % Peak intensity 4.2 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED XHP35.2 HI FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 4.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED XM-L3 FWHM / FWTM Asymmetric Efficiency 87 % Peak intensity 3.7 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass Last update: 31/01/2024 Subject to change without prior notice Published: 07/07/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/21 PRODUCT DATASHEET C17411_SPORT-2X2-S2 OPTICAL RESULTS (SIMULATED): LED XM-L3 FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 4.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G2 HE FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 5.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G3 FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED XP-L HD FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 5.1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 31/01/2024 Subject to change without prior notice Published: 07/07/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/21 PRODUCT DATASHEET C17411_SPORT-2X2-S2 OPTICAL RESULTS (SIMULATED): LED XP-L HD FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED XP-L HI FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 5.5 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED XP-L HI FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 5.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L2 FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 4.2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 31/01/2024 Subject to change without prior notice Published: 07/07/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/21 PRODUCT DATASHEET C17411_SPORT-2X2-S2 OPTICAL RESULTS (SIMULATED): LED XP-L2 FWHM / FWTM Asymmetric Efficiency 87 % Peak intensity 3.8 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED XP-P FWHM / FWTM Asymmetric Efficiency 97 % Peak intensity 8.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-P FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 7.6 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED LUXEON 3030 2D (Round LES) FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 7.4 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass Last update: 31/01/2024 Subject to change without prior notice Published: 07/07/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/21 PRODUCT DATASHEET C17411_SPORT-2X2-S2 OPTICAL RESULTS (SIMULATED): LED LUXEON 5050 HE FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 3.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 5050 HE FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED LUXEON 5050 Round LES FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 3.6 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED LUXEON 5050 Square LES FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass Last update: 31/01/2024 Subject to change without prior notice Published: 07/07/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/21 PRODUCT DATASHEET C17411_SPORT-2X2-S2 OPTICAL RESULTS (SIMULATED): LED LUXEON 5050 Square LES FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 3.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 7070 FWHM / FWTM Asymmetric Efficiency 95 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON XR-HL2X (L2H2-xxxxxxxMLU010) FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 5.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON XR-HL2X (L2H2-xxxxxxxMLU010) FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 4.7 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass Last update: 31/01/2024 Subject to change without prior notice Published: 07/07/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/21 PRODUCT DATASHEET C17411_SPORT-2X2-S2 OPTICAL RESULTS (SIMULATED): LED SST-70X-WCS FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 3.7 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED SST-70X-WCS FWHM / FWTM Asymmetric Efficiency 97 % Peak intensity 4.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED NV4WB35AM FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 4.4 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED NVSW219D FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 4.6 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass Last update: 31/01/2024 Subject to change without prior notice Published: 07/07/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/21 PRODUCT DATASHEET C17411_SPORT-2X2-S2 OPTICAL RESULTS (SIMULATED): LED NVSW219F FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 4.6 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED NVSW3x9A FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 4.9 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED NVSxE21A FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 7.6 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED Duris S8 FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass Last update: 31/01/2024 Subject to change without prior notice Published: 07/07/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/21 PRODUCT DATASHEET C17411_SPORT-2X2-S2 OPTICAL RESULTS (SIMULATED): LED Duris S8 FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ C 2424 FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 2.3 cd/lm LEDs/each optic 4 Light colour White Required components: LED OSCONIQ C 3030 FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 6.6 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED OSCONIQ P 3737 (2W version) FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 6.8 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass Last update: 31/01/2024 Subject to change without prior notice Published: 07/07/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/21 PRODUCT DATASHEET C17411_SPORT-2X2-S2 OPTICAL RESULTS (SIMULATED): LED OSCONIQ P 3737 (3W version) FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 5.4 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED OSCONIQ P 3737 Flat FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 6.4 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED OSCONIQ P 3737 Flat FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 6.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ S 5050 FWHM / FWTM Asymmetric Efficiency 97 % Peak intensity 3.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 31/01/2024 Subject to change without prior notice Published: 07/07/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/21 PRODUCT DATASHEET C17411_SPORT-2X2-S2 OPTICAL RESULTS (SIMULATED): LED OSCONIQ S 5050 FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED OSLON Square Flat FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 7.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square Flat FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 7.3 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED OSTAR Projection Compact (KW.CSLNM1.TG) FWHM / FWTM Asymmetric Efficiency 97 % Peak intensity 7.1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 31/01/2024 Subject to change without prior notice Published: 07/07/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/21 PRODUCT DATASHEET C17411_SPORT-2X2-S2 OPTICAL RESULTS (SIMULATED): LED LH351B FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 5.3 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED LH351C FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 5.1 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED LH351D FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 4.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH351D FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 4.1 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass Last update: 31/01/2024 Subject to change without prior notice Published: 07/07/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/21 PRODUCT DATASHEET C17411_SPORT-2X2-S2 OPTICAL RESULTS (SIMULATED): LED LH502C FWHM / FWTM Asymmetric Efficiency 89 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED LH502C FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED MJT 5050 FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED SEOUL DC 5050 6V FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass Last update: 31/01/2024 Subject to change without prior notice Published: 07/07/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/21 PRODUCT DATASHEET C17411_SPORT-2X2-S2 OPTICAL RESULTS (SIMULATED): LED SEOUL DC 5050 6V FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5M3 FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 5.4 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED Z5M4 FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 6.7 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass LED Z5M5 FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 5 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass Last update: 31/01/2024 Subject to change without prior notice Published: 07/07/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/21 PRODUCT DATASHEET C17411_SPORT-2X2-S2 OPTICAL RESULTS (SIMULATED): LED Z5M5 FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 5.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y22 FWHM / FWTM Asymmetric Efficiency 95 % Peak intensity 6.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 31/01/2024 Subject to change without prior notice Published: 07/07/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/21 PRODUCT DATASHEET C17411_SPORT-2X2-S2 GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 31/01/2024 Subject to change without prior notice Published: 07/07/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/21
C17411_SPORT-2X2-S2 价格&库存
很抱歉,暂时无法提供与“C17411_SPORT-2X2-S2”相匹配的价格&库存,您可以联系我们找货
C17411_SPORT-2X2-S2
    • 140+22.08249140+2.85440
    C17411_SPORT-2X2-S2
      C17411_SPORT-2X2-S2
        C17411_SPORT-2X2-S2
