CS17758_STRADA-IP-24-T3-M-PC
    LEDIL(芬兰)
    透镜 透明 螺钉
CS17758_STRADA-IP-24-T3-M-PC 数据手册
PRODUCT DATASHEET CS17758_STRADA-IP-24-T3-M-PC STRADA-IP-24-T3-M-PC IESNA Type III (medium) beam with excellent backlight control, illuminance uniformity and cutoff. Variant made from PC. SPECIFICATION: Dimensions 173.0 x 71.4 mm Height 9 mm Fastening pin, screw Ingress protection classes IP66, IP67 ROHS compliant yes MATERIALS: Component Type Material Colour STRADA-IP-24-T3-M-PC Multi-lens PC clear STRADA-IP-24-SEAL Seal Silicone white Finish ORDERING INFORMATION: Component CS17758_STRADA-IP-24-T3-M-PC » Box size: 476 x 273 x 247 mm Qty in box 120 MOQ MPQ 120 40 Box weight (kg) 7.0 Last update: 16/01/2024 Subject to change without prior notice Published: 26/07/2022 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/7 PRODUCT DATASHEET CS17758_STRADA-IP-24-T3-M-PC See also our general installation guide: www.ledil.com/installation_guide Last update: 16/01/2024 Subject to change without prior notice Published: 26/07/2022 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/7 PRODUCT DATASHEET CS17758_STRADA-IP-24-T3-M-PC OPTICAL RESULTS (MEASURED): LED LIGHT ENGINE STRADA-IP 24 LEDs 147.4 x 46.2 x 1.5 FWHM / FWTM Asymmetric Efficiency 84 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 5050 Square LES FWHM / FWTM Asymmetric Efficiency 83 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON XR-5050 HE (L225-xxxx024MLU010) FWHM / FWTM Asymmetric Efficiency 85 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris S8 FWHM / FWTM Asymmetric Efficiency 84 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 16/01/2024 Subject to change without prior notice Published: 26/07/2022 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/7 PRODUCT DATASHEET CS17758_STRADA-IP-24-T3-M-PC OPTICAL RESULTS (MEASURED): LED HiLOM RM24 ZP (LH502D) FWHM / FWTM Asymmetric Efficiency 85 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 16/01/2024 Subject to change without prior notice Published: 26/07/2022 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/7 PRODUCT DATASHEET CS17758_STRADA-IP-24-T3-M-PC OPTICAL RESULTS (SIMULATED): LED Bridgelux SMD 5050 FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED J Series 5050B 30V K Class FWHM / FWTM Asymmetric Efficiency 76 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED J Series 5050B 6V K Class FWHM / FWTM Asymmetric Efficiency 81 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED J Series 5050C 6V E Class FWHM / FWTM Asymmetric Efficiency 81 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 16/01/2024 Subject to change without prior notice Published: 26/07/2022 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/7 PRODUCT DATASHEET CS17758_STRADA-IP-24-T3-M-PC OPTICAL RESULTS (SIMULATED): LED NFMW48xA FWHM / FWTM Asymmetric Efficiency 79 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ S 5050 FWHM / FWTM Asymmetric Efficiency 89 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH502C FWHM / FWTM Asymmetric Efficiency 82 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH502D FWHM / FWTM Asymmetric Efficiency 81 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 16/01/2024 Subject to change without prior notice Published: 26/07/2022 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/7 PRODUCT DATASHEET CS17758_STRADA-IP-24-T3-M-PC GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 16/01/2024 Subject to change without prior notice Published: 26/07/2022 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/7
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
CS17758_STRADA-IP-24-T3-M-PC 价格&库存
很抱歉,暂时无法提供与“CS17758_STRADA-IP-24-T3-M-PC”相匹配的价格&库存,您可以联系我们找货
    • 40+37.1764740+4.66200
    • 80+36.8224180+4.61760
    • 120+36.64538120+4.59540
    • 200+36.37983200+4.56210
    • 400+35.76022400+4.48440
      • 40+43.2840340+5.42790
      • 120+42.66442120+5.35020
      • 200+42.39888200+5.31690
      • 400+42.04481400+5.27250
      • 800+41.42521800+5.19480
      • 1+97.64014
      • 10+79.05144
      • 50+60.56688
      • 100+53.67292
      库存:40
