0055382A2
0055382A2
    MAGNETICS(美磁)
    有涂层 MPP 铁氧体磁芯磁环 型 长度 宽 0.680"(17.27mm) 直径 0.250"(6.35mm) 高
0055382A2 数据手册
0055382A2 MAGNETICS AL (nH/T2) 26 19 ± 8% Part Number 55382A2 Inductance Grade N/A Coated Limits Coating Color Gray Packaging (mm) (in) (mm) (in) OD (A) 17.27 0.680 18.03 0.710 max ID (B) 9.65 0.380 9.02 0.355 min HT (C) 6.35 0.250 7.11 0.280 max Bulk Pack 4 bags/box Box Qty= 2000 pcs Physical Characteristics DC Bias min (oersteds) 80% 120 Lot Number XXXXXX Uncoated Electrical Characteristics 800 Core Marking MPP Permeability (µ) Dimensions Watt Loss @ 100 kHz, 100mT max (mW/cm3) 110 Delta Drive Pittsburgh, PA 15238 NAFTA Sales: (1)800-245-3984 HK Sales : (852)3102-9337 magnetics@spang.com www.mag-inc.com 50% 215 Voltage Breakdown wire to wire min (VAC) Break Strength min (kg) Window Area WA(mm2) Cross Section Ae (mm2) Path Length Le (mm) Volume Ve (mm3) Weight (g) >2000 28.0 63.8 23.2 41.4 960 7.0520 Winding Information Winding Length Per Turn Winding Factor (mm) Winding Factor (mm) 0% 20% 25% 30% 35% 23.2 25.6 26.2 26.6 27.4 40% 45% 50% 60% 70% 28.0 28.6 29.3 30.8 32.4 Temperature Rating Curie Temp: 460 ˚C Wound Coil Dimensions (mm) OD 40% Winding Factor HT Max OD Completely Full Window Max HT 19.6 10.1 24.9 16.3 Coating Temp (Continuous up to): 200 ˚C Notes: Surface Area (mm²) Unwound Core 40% Winding Factor 990 1,400 Typical DC Bias Performance 20.0 18.0 80% 16.0 AL (nH/T2) 14.0 12.0 50% 10.0 8.0 6.0 4.0 2.0 0.0 0 200 400 600 800 1000 1200 A·T Revision 10/6/2021
0055382A2 价格&库存
很抱歉,暂时无法提供与“0055382A2”相匹配的价格&库存,您可以联系我们找货
0055382A2
  • 1+73.542041+9.54442
  • 10+49.6613610+6.44514
  • 25+41.7243925+5.41507
  • 50+36.2082650+4.69917
  • 100+31.06617100+4.03183
  • 250+31.01076250+4.02463
库存:1353
